Help with 4101 Windshield Replacement Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » October 2008 » Help with 4101 Windshield Replacement « Previous Next »
Drew Sears (Drooby)
Username: Drooby
Post Number: 1
Posted From: 72.188.174.201
Posted on Friday, October 24, 2008 - 2:31 pm:
I need to replace both windshields on my 1960 4104. Am I better off taking to a shop or is it easy enough to replace them on my own. I have heard of a NJ site that sells and ships them but I have not found a contact there. I appreciate any help.
Username: Luvrbus
Post Number: 558
Posted From: 74.33.57.23
Posted on Friday, October 24, 2008 - 3:31 pm:
Try this Drew www.curvedglassdist.com they are located in Derby CT. 1-800-243-6546 they charge the same shipping for 2 windshields as they do for one.Luke my have them also and he is in NJ someone will have a contact for him I don't good luck
Keith Wood (Ft6)
Username: Ft6
Post Number: 50
Posted From: 71.198.253.223
Posted on Friday, October 24, 2008 - 6:02 pm:
Think about this. You're dealing with a large, heavy item which breaks easily. No way you're doing it alone unless you have experience and plenty of upper-body strength. Do you have the tools? What are you going to do with the old one? These are all arguments in favor of using the "folding toolbox" (your wallet).
Also, if you pay a shop to do it, you pay when it's done. If they break it, they have to replace it and do it right. If you break it, you broke it and you get to buy another and try again.
Call around, you may find a truck shop that will do the job at a good price, and it's worth it.
Post Number: 310
Posted From: 71.55.193.233
Posted on Friday, October 24, 2008 - 8:47 pm:
I bought mine from curved glass and picked them up at the terminal and brought them home,backed up to the coach, removed the old glass and gasket,got the soap in a spray bottle put the moulding in place,got my 2-suction cup[Harbor Freight 4.95 special] uncrated the glass and one was run thru with a fork lift, got on the phone and was shipped another overnight, continued the next day and after all was said and done I spent 2-3 hours total in installation. Not hard to do just remember treat it like it is a piece of metal and you won't break it. Just watch the pros do it. Gee what a frightning site. If you are in GOOD OLE FLORIDA come on by and I'll help you anytime. I also had the tool to put it in with from snap on tool co. and that helps bunches.
Drew Sears (Drooby)
Username: Drooby
Post Number: 2
Posted on Saturday, October 25, 2008 - 2:03 am:
Thanks for the help, I do have auto experience replacing windshields but I think I will have a shop replace them. Thanks for the link to purchase also.I am taking the bus from OK to FL in January so we can tool down to the Keys in the spring.
Username: Gusc
Post Number: 750
Posted From: 208.54.200.90
Posted on Sunday, October 26, 2008 - 10:10 pm:
Drew,
Same as Gomer. I haven't replaced the fronts yet but did all three rears on mu 4104 which are probably more difficult because they are much higher off the ground.
I had help for one minute getting the large center glass into the bottom of the gasket. Did all the rest alone and I'm a wimpy old guy.
I have to do my two soon also but have no hesitation about doing them alone.
I would say they are at least as easy as auto windshields, probably much easier than the newer glued in ones.
Be sure to get a new gasket unless yours is almost new, prevents any leaks.
Let us know what you finally do and where you get the glass.
