More on split air conditioning Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » July 2002 » More on split air conditioning « Previous Next »
carl white (66.219.157.56)
Posted on Wednesday, July 24, 2002 - 11:33 pm:
I read the tread on split air conditioning to late to ask questions on it?
Ace talks about his sanyo units and ktrout01 talks about the hitachi.
Where do you get information on these units? Where can you purchase them and about how much do they cost?
thanks for the additional information
carl
jmaxwell (66.42.92.3)
Posted on Thursday, July 25, 2002 - 12:12 am:
Check down the threads to last week on the Hitachi. He posted a web site, I'm sure there is a dealer in your area. They were $477+freight. Nice units and the EER was great, but the evap. unit was a bit wide at 30 inches, and the condensing unit was not very compact, also being 30" wide.
Ace (24.28.44.126)
Posted on Thursday, July 25, 2002 - 8:09 am:
More info for our Sanyo units can be found by going here:
http://sanyo.com/business/hvac/index.cfm
Hope this helps!
Ace
ktrout01 (207.190.253.82)
Posted on Friday, July 26, 2002 - 10:30 am:
Either the Hitachi or Sanyo look like a nice option. The inside units would take up quite a bit of wall space but it could be worth it. The Sanyo unit that I've seen installed in an office is VERY quiet. I would probably mount the rear unit over the headboard and the front unit maybe over the couch. I don't plan on having any cabinets above the couch so that could work well. The front compressor unit could be mounted in the existing A/C bay which already has a grill and the rear unit would need a grill in one of the baggage doors or some type of ductwork if I wanted to mount it inside the bay. I looked at one of the dual zone units but the voltage required is 208/220 so that doesn't work out well for most campgrounds. While it would cut down on the amount of machinery it would require a bigger generator or shore power availability to make it go.
Another plus is with it being a fairly common unit, parts and repairs could be pretty easy to come by in most areas. Installation is certainly harder than a rooftop unit. but what the heck ?
Jayjay (65.142.15.87)
Posted on Friday, July 26, 2002 - 9:24 pm:
Think how nice it will be to back into a spot beneath a lovely shade tree, and NOT have to worry about wiping out your $800.00 roof top unit !!! Cheers...JJ
Ace (24.28.44.126)
Posted on Saturday, July 27, 2002 - 4:46 pm:
Ktrout01 our rear unit actually sits on the floor against the wall and takes up about 8 inches of space out from the wall. You don't even notice it's there! It's blows VERY cold air in all directions and in the winter, we almost have to turn the a/c on instead of the heat once the heat has been activated due to it's VERY good heating capabilities!
The wall units we have take up about 10 inches of space and they simply hang on the wall once they are plumbed to the unit down below! These units are also remote controlled, VERY quiet, and VERY cold!
Both units are attractive and blend right in with our decor!
Hope this helps!
Ace
krtrout (12.243.136.90)
Posted on Saturday, July 27, 2002 - 6:25 pm:
Ace, Did you build cabinets inside to house the cond. units ? That would be a pretty good way to go and still save your under storage space. It would also make the plumbing run real short and protect them from damage in the bays. Where did you buy yours and if you don't mind me asking ... What the $$$ was. Reply off line if you'd like.
Thanks
Arthur Butt (24.128.29.226)
Posted on Saturday, July 27, 2002 - 9:08 pm:
Ace,
I have been follwing the questions and answers and I am very interested in thei option. Can you answer a few questions?
1)What brand are you using
2) Are you using the 2 condenser units
3) Are they 110 or 220 volt
4) Where did you get them and how $$
You can email me if you would prefer.
Thanks
Arthur
RC Bishop (128.123.88.45)
Posted on Sunday, July 28, 2002 - 8:59 pm:
Hey guys, I was really looking forward to the answers to the above questions. This has been an interesting and pretty informative thread....could I encourage you all to keep it public?.. I imagine there are a bunch of folks who would like to get the scoop on all of the above questions.... and hate to burden each individual asking it to be repeated.
Thanx a bunch, and what a GREAT board, as I've said before so many times.
RCB :)
ace (24.28.44.126)
Posted on Monday, July 29, 2002 - 8:09 am:
I will be posting info about whatwe have in our Eagle later today! To the ones that e-mailed me, I got home late yesterday from golf and it was too dark to do anything. I will do it today after work since I should be home early! :)
Ace
