Detonation Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » November 2008 » Detonation « Previous Next »
Username: Joemc7ab
Post Number: 307
Posted From: 66.38.159.33
Posted on Monday, November 24, 2008 - 12:21 am:
I very recently acquired a couple of 1990 Prevost XL's equipped with 6V92's and 6 speeds. That will have to be the subject of another post!!!!!
Both were non runners supposedly, but I got one running and it suffers from detonation.
Da Book suggests a couple of causes:
(a) oil picked in the air stream
(b) low coolant temperature (not likely,since it does it with the temperature at 170*F
(c) Faulty injectors.
Which in the humble opinion of our Detroit experts would be the likely source?
I have not yet removed the turbo etc. to have a look inside the blower if oil is bypassing the seal.
Awaiting your opinions,
Joe.
Dan West (Utahclaimjumper)
Username: Utahclaimjumper
Post Number: 130
Posted From: 208.66.38.60
Posted on Monday, November 24, 2008 - 8:43 am:
Joe, its supposed to detonate, thats what diesels do!!!!>>>Dan
Grant Thiessen (Busshawg)
Username: Busshawg
Post Number: 67
Posted From: 206.45.93.160
Posted on Monday, November 24, 2008 - 10:26 am:
I'm no expert but have had this issue that was caused by a faulty injector.
Have fun
Post Number: 344
Posted From: 71.55.230.210
Posted on Monday, November 24, 2008 - 9:07 pm:
Check the color of the smoke coming out the exhaust. Chanches are: at idle if you have faulty injector or injectors, first it will burn the eyes,white smoke, will kinda puff at you. I had one that had white smoke and when you mashed the gas it would spit black and white. Gray smoke is oil not fuel tho. Just a thought
Gomer
