Block Heater: How Long Plugged In? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » December 2008 » Block Heater: How Long Plugged In? « Previous Next »
james dean boggs (Jd_boggs)
Username: Jd_boggs
Post Number: 133
Posted From: 71.102.32.163
Posted on Saturday, December 20, 2008 - 8:23 pm:
Have 1500 watt block heater never used before. Do I keep it plugged in all night or just a few hours? It's been 17-19 degrees at night and will need to travel next few days.
Thanks all.
David Lower (Dave_l)
Username: Dave_l
Post Number: 116
Posted From: 67.58.201.10
Posted on Saturday, December 20, 2008 - 8:26 pm:
It wont hurt to leave it pluged in all night.
Dave L
Username: Timb
Post Number: 241
Posted From: 74.244.14.221
Posted on Saturday, December 20, 2008 - 8:27 pm:
When I took my last trip I just turned mine on before I went to bed then she was all ready in the morning
Dan West (Utahclaimjumper)
Username: Utahclaimjumper
Post Number: 147
Posted From: 208.66.38.60
Posted on Saturday, December 20, 2008 - 8:41 pm:
Usually a couple of hours will do it, much more is a waste of electricity ($$$$)>>>Dan
Post Number: 1435
Posted From: 76.68.133.120
Votes: 2 (Vote!)
Posted on Saturday, December 20, 2008 - 10:58 pm:
Hello.
How long do you engage your engine heating apparatus?
As long as it takes to get the engine warm enough to start.
So, do some trials. Another dandy use for your infra red temp gun.
See how long it takes your heater to raise the temp of the block to what terminal temp, in what conditions?
Always looking for a way to save a buck? Don't want that heater on any longer than necessary!
Worth the convenience? Leave it plugged in overnight.
My world?
1500 watt block heater in an 8V71, snow covered landscape, two hours does the job.
-30C/-22F? 20 minute burn of a Webasto DBW300. (1/3 gallon of fuel) and she'll fire!
Post Number: 611
Posted From: 69.19.14.16
Posted on Sunday, December 21, 2008 - 6:34 am:
When traveling we plug it in on arrival at the campsite and leave it on till departure.
NICE!! to start in 1/2 turn, at freezing .
FF
Frank Allen (Frank66)
Username: Frank66
Post Number: 100
Posted From: 64.12.117.73
Posted on Sunday, December 21, 2008 - 10:23 am:
i can turn mine on for 45 mins and it starts right up,
Frank allen 4106
Mel La Plante (Mel_4104)
Username: Mel_4104
Post Number: 106
Posted From: 205.250.187.86
Posted on Sunday, December 21, 2008 - 11:32 am:
it will not hurt to leave the block heater on over nite, in fact i like to do just that as it tends to warm up the whoke inside area of the engine compartment and heats the compressor,warms the power steering oil and even conducts heat to the tranny. this all helps to the oil moving better. up here we even put a heater on the bottom of the tranny of our equipment, sure saves on wear as the oil lubs much better and no cold running before the oil warms up. even a light bulb put under the oil pan is a great help.
William D. Watkins (Sivrtnge2)
Username: Sivrtnge2
Post Number: 207
Posted From: 173.110.98.144
Posted on Sunday, December 21, 2008 - 4:57 pm:
Well, I guess I need to ask...will it hurt anything to leave it plugged in months at a time??? I plugged mine in back in October...haven't been home since. Not worried about the electric bill because the only thing on is the engine heater, a few house lights, and the heatpump set at 50 degrees for the house.
BILL
Username: Kyle4501
Post Number: 451
Posted From: 65.12.126.44
Posted on Sunday, December 21, 2008 - 8:13 pm:
I had 2 block heaters so I plugged 'em both in for a month while I postponed replacing the antifreeze. The heaters were 1500 watts each & don't have thermostats to turm 'em off, so that added up all too quickly.
The bill was a lot more than I was planning for. Even tho they were the only things plugged in after that meter.
I suppose adding a thermostat would pay for itself rather quickly if I feel the need to do that again. . . .
Bill, I hope your elec bill isn't what mine was.
Don Evans (Doninwa)
Username: Doninwa
Post Number: 174
Posted From: 208.81.157.90
Posted on Sunday, December 21, 2008 - 9:26 pm:
Here in the Northwest with cheep power a 1500 watt heater would cost about $75 a month @ 6.9 cents/KW. What does 1080KW cost were you are?
Don 4107
Username: Pvcces
Post Number: 1243
Posted From: 65.74.69.188
Posted on Sunday, December 21, 2008 - 10:35 pm:
Bill, the $100 per month saved on electricity could go towards fuel to help pay for a trip! You will need cheap power to keep it down to $100.
For what it's worth.
Suncatcher
Ketchikan, Alaska
Floyd Lillies (Flois)
Username: Flois
Post Number: 6
Posted From: 216.86.127.176
Posted on Sunday, December 21, 2008 - 10:45 pm:
I use a programmable timer to warm the block "just in time" to fire up the coach and head out in the morning ... one hour to 3 hours depending on the outside temperature.
Username: Jd_boggs
Post Number: 134
Posted on Sunday, December 21, 2008 - 11:01 pm:
I'm paying .064 cents per kW hour $69 per month. When the solar panels get installed here in So Cal it should drop even more. I'm already surrounded by wind generators. My last count of wind generators in my vicinity is over 1,000 units and there crews installing more.
Username: Sivrtnge2
Post Number: 208
Posted From: 68.30.38.2
Posted on Sunday, December 21, 2008 - 11:19 pm:
I guess I might be in trouble!!!
BILL
Username: Sivrtnge2
Post Number: 209
Posted on Sunday, December 21, 2008 - 11:23 pm:
As for fuel money to take a trip...I produce my own fuel. After I refine it, I charge myself 5.999 per gallon for it. Thats cheap compaired to most. I just might have to raise the price per gallon to keep up with the economy!!!
BILL
Username: Kyle4501
Post Number: 452
Posted From: 65.23.106.193
Posted on Monday, December 22, 2008 - 8:43 am:
Yep, ~$80 per heater per month is what I remember paying. :-(
It didn't take long to justify new coolant! :-)
Username: Sivrtnge2
Post Number: 210
Posted From: 173.108.172.74
Posted on Monday, December 22, 2008 - 12:19 pm:
My better half said it is costing us about 40.00 per month. Our bill has jumped from 80.00 to 120.00. She said for Nov. and Dec. I figure 3 to 4 months per year...worse case 160.00 isn't bad. I'll right it off to "U.N.C.L.E. S.A.M.
Username: Pd41044039
Post Number: 349
Posted From: 69.77.157.42
Posted on Monday, December 22, 2008 - 12:59 pm:
William, are you working for Uncle Sam? Did you get called about 6 months ago?
Username: Sivrtnge2
Post Number: 211
Posted From: 173.110.88.82
Posted on Monday, December 22, 2008 - 6:00 pm:
Everyday!!! I got called about 8 years ago. Been in active duty ever since!!!
BILL
