Barry McCully (Turtle)
Registered Member Username: Turtle
Post Number: 30 Registered: 8-2007 Posted From: 24.89.235.12
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 24, 2009 - 5:37 am: | |
Just wondering if anyone knows of any plans on how to build a storage bed slide for my underneath storage compartments. |
Larry D Baker (Lbaker4106)
Registered Member Username: Lbaker4106
Post Number: 85 Registered: 5-2005 Posted From: 174.42.208.19
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 24, 2009 - 8:07 pm: | |
I made one for my 4106 out of 1 inch rollers I got at an auction. I held the rollers in place with 1 inch square tubeing and made a deck out of tongue and groove plywood. 12 rollers total and perforated angle to keep the deck in place. |
Bill Gerrie (Bill_gerrie)
Post Number: 222 Registered: 3-2006 Posted From: 216.198.139.38
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 25, 2009 - 10:25 am: | |
Barry You can buy full extension drawer slides that work well and can hold up to 500 lbs. They fit on the side and only take up 3/4" on each side. I made my battery tray with them. You can get them in any length up to 60" at most commercial truck body builders hardware suppliers. Do a search online as well. Bill |
Post Number: 392 Registered: 3-2007 Posted From: 71.55.230.210
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 25, 2009 - 7:50 pm: | |
SOMEONE HAD PUT IN LIKE GARAGE DOOR TRACKS AND HAD PUT THE ROLLERS CLOSE TOGETHER SO AS TO DISTRIBUTE THE WEIGHT. hAVEN'T TRIED IT BUT THAT SOUNDS OK FOR LIGHT WEIGHT OPERATION. GOMER |
Post Number: 663 Registered: 10-2006 Posted From: 69.19.14.28
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 27, 2009 - 6:48 am: | |
If you get down to Airborne Surplus near Orlando you can find (sometimes) US Gov NASA computer glides. Have seen 2 8D batts mounted in them for EZ service . FF |
Keith Wood (Ft6)
Registered Member Username: Ft6
Post Number: 79 Registered: 8-2008 Posted From: 75.209.200.245
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 27, 2009 - 10:00 am: | |
I like the 1" roller idea better than drawer slides. If you bend or damage a slide, you've had it! Your only options are to replace it now (while will take a while) or jam the slide back in and deal with more damage later. Look at cargo planes, and they use rollers because of the versatility. More important for us, rollers distribute the weight more evenly. Going back to "versatility," in a coach it means that you can have several different trays instead of having to move the whole load in and out every time. This can be important, if you need to get out your toolbox to fix the problem that has your coach tilting toward the other side! |
