1974 MC8 Crusader II Stainless Steel ... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » February 2009 » 1974 MC8 Crusader II Stainless Steel Polishing « Previous Next »
Moti Nowrangi (Mnowrangi)
Username: Mnowrangi
Post Number: 2
Posted From: 96.255.56.102
Posted on Sunday, February 08, 2009 - 7:37 am:
What is the best compound to use in buffing up and polishing up the stainless steel on the sides of the bus? I've seen cans of "aluminium" polish at Advanced Auto Parts and similar elsewhere....I know it will take a lot of time and patience, but it is a project! Perhaps, something of commerical grade is available at Home Depot?
Username: Jackconrad
Post Number: 955
Posted From: 71.54.29.215
Posted on Sunday, February 08, 2009 - 9:09 am:
I get my polish and polishing wheels from International Bus & Parts in Apopka, Florida 1-800-468-5287. the polish comes in "bricks". I start with black (emory), then red (tripoli), then blue, then white. I use different wheels with each compound. I use 2 wheels at a time on a 9" angle grinder/polisher. The wheels are like those used on a stationary polisher (you are using the edge of the wheels, not the flat side.
Polishing compound is also available from Grainger's and probably other sources. Jack
john degemis (Degemis)
Username: Degemis
Post Number: 45
Posted From: 71.92.155.232
Posted on Sunday, February 08, 2009 - 10:05 am:
My sides were very dull and lots of scratches. I found wet sanding starting from 220 on the deeper scratches and 400 on the rest and going grade by grade to a 2000 grit gave me a nice even finish. Using a sanding block/sponge and raping the paper around it made the job pretty easy. To get to a chrome look I used the steeps Jack mentioned.
Username: Mnowrangi
Post Number: 4
Posted on Monday, February 09, 2009 - 11:54 am:
Will "Brasso" do the work in polishing the stainless portions of my MC8 (luggage bay areas, front and rear, etc.)?
Grant Thiessen (Busshawg)
Username: Busshawg
Post Number: 110
Posted From: 206.45.93.160
Posted on Tuesday, February 10, 2009 - 3:56 pm:
jewelers rouge, and a buffer in a horizantal position, available at many truck stops
