Recommendation for tire inflator Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » February 2009 » Recommendation for tire inflator « Previous Next »
Bob McSeveney (Scout70)
Username: Scout70
Post Number: 4
Posted From: 24.22.240.106
Posted on Thursday, February 12, 2009 - 9:54 am:
I have a 73 MCI 5b challenger and would like to carry some type of portable tire inflator. Does anyone have a recommendation or suggestion on a quality reasonably priced inflator/compressor?
Thanks.
Username: Timb
Post Number: 269
Posted From: 66.165.176.62
Posted on Thursday, February 12, 2009 - 9:57 am:
I just put a quick connect fitting after the dump valve on my wet tank and I use bus air
Dan West (Utahclaimjumper)
Username: Utahclaimjumper
Post Number: 154
Posted From: 208.66.38.115
Posted on Thursday, February 12, 2009 - 10:29 am:
As long as you have bus air you might as well use it, you can carry along a small portable inflatable tank to be portable.>>>Dan 4106-1261
Username: Lsilva
Post Number: 203
Posted From: 24.164.20.23
Posted on Thursday, February 12, 2009 - 11:06 am:
And while you're at it, get a locking tire chuck. Holding the chuck for 20 minutes while you inflate a tire can be maddening
(Message edited by lsilva on February 12, 2009)
Roger Baughman (Roger)
Username: Roger
Post Number: 68
Posted From: 75.3.207.153
Posted on Thursday, February 12, 2009 - 5:40 pm:
What and where is the wet tank and dump value?
Username: Timb
Post Number: 270
Posted on Thursday, February 12, 2009 - 5:50 pm:
The wet tank is the first tank after the air compressor and it usually has a valve on it to dump out water that accumulates in the tank. Don't know about your type of coach on my Flx the tank is on the drivers side rear just behind the rear tire
David Lower (Dave_l)
Username: Dave_l
Post Number: 126
Posted From: 67.58.201.10
Posted on Thursday, February 12, 2009 - 6:57 pm:
Roger on my 1973 MC7 there is a tank below the drivers floor, you get access to it by a door in front of the drivers front wheel. open the door and it is above the opening. this is where I have a air line hooked up to inflate tires or run air tools. Dave L
Username: George_mc6
Post Number: 727
Posted From: 64.55.111.6
Posted on Thursday, February 12, 2009 - 8:09 pm:
Take Dave's advice, as the air you get out of the aux tank will be much cleaner.
G
Post Number: 489
Posted From: 75.211.14.83
Posted on Thursday, February 12, 2009 - 8:13 pm:
Tim...all my air tanks have "dumps" on them....are you sure yours do not? Might want to check if you haven't. And if they don't work right....they're cheap.
FWIW :-)
1964 Crown Supercoach (HWC)
Post Number: 490
Posted on Thursday, February 12, 2009 - 8:15 pm:
Len...Amen to that...I didn't know about the locking chucks, but I'll be chasin' them down PDQ.
Thanx for the "heads up"!!! :-)
Username: Timb
Post Number: 271
Posted From: 74.244.14.221
Posted on Thursday, February 12, 2009 - 10:06 pm:
RC yes they do but I only have two tanks in tandem in the rear. The only thing on my Flx that is air other than the brakes are the wipers and horn
Post Number: 493
Posted on Thursday, February 12, 2009 - 10:11 pm:
Tim...nothing "up front"?
Kevin Black (Kblackav8or)
Username: Kblackav8or
Post Number: 107
Posted From: 24.152.162.226
Posted on Saturday, February 14, 2009 - 4:10 pm:
http://www.amazon.com/Snap-Ball-Foot-Chuck-Clip/dp/B001LMUN26/ref=sr_1_1?ie=UTF8&s=hi&qid= 1234645785&sr=8-1
Username: Lsilva
Post Number: 204
Posted on Saturday, February 14, 2009 - 6:21 pm:
Kevin, You'll find that ball foot chuck difficult to use on the inside duals.
