Power Steering oil turned cloudy Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » February 2009 » Power Steering oil turned cloudy « Previous Next »
james dean boggs (Jd_boggs)
Username: Jd_boggs
Post Number: 135
Posted From: 71.102.16.82
Posted on Wednesday, February 25, 2009 - 4:58 pm:
Went to check oil levels before a trip and looked through the sight glass of the power steering reservoir and is cloudy. It has always been darkish in color just like motor oil. Anybody have ideas as to what it could have caused this? The steering works fine just gets a little stiff once in awhile.
Is my pump shot? Thanks.
john daniels (Big_john)
Username: Big_john
Post Number: 13
Posted From: 75.109.199.111
Posted on Wednesday, February 25, 2009 - 5:19 pm:
water
Username: Luvrbus
Post Number: 649
Posted From: 74.32.92.133
Posted on Wednesday, February 25, 2009 - 6:46 pm:
let it set for awhile if it clears you have air in sysytem if not like John says water good luck
Username: Jd_boggs
Post Number: 136
Posted on Thursday, February 26, 2009 - 11:35 pm:
I noticed a month ago that the level was low and added the prescribed oil type and now it is cloudy. I ruled out water because it is a closed system. Any other comments?
Don Evans (Doninwa)
Username: Doninwa
Post Number: 186
Posted From: 208.81.157.90
Posted on Friday, February 27, 2009 - 12:03 am:
Could be incompatible oils. Saw it happen once. Stuff foamed right out the filler neck. Don't know what the mix was but it was a mess. Had to take the return off and keep pouring fresh oil in while turning the steering lock to lock until oil cleared up.
Don 4107
Username: Dougthebonifiedbusnut
Post Number: 81
Posted From: 75.69.223.64
Posted on Friday, February 27, 2009 - 11:04 pm:
OMG John-I just had a flashback!
