Post Number: 1597 Registered: 12-2000 Posted From: 67.182.53.218
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 29, 2009 - 12:55 am: | |
Went out to the coach today to prep it for moving from the storage lot to the pad next to the garage. This is what I found:
Yup, somebody's artwork, along with two new broken windows. PD took a vandalism report, but otherwise shrugged their shoulders. Can't do much w/ lot owner - written agreement is "park at your own risk". FWIW. . .
Bob MacIsaac (Wildbob24)
Post Number: 39 Registered: 5-2007 Posted From: 68.158.246.144
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 29, 2009 - 2:06 am: | |
RJ, I feel for ya. At least yours is somewhat artistic. Here's my first 4106:
Post Number: 584 Registered: 3-2007 Posted From: 71.53.155.14
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 29, 2009 - 8:50 am: | |
RJ, Sorry about your delema maybe some mineral spirits will remove that garbage, If not go to lowes,home depot or the local hardware store and get graffiti remover. I haven't found it to remove anything but that depending on the age of the artistic work. Good Luck Gomer |
Post Number: 186 Registered: 10-2006 Posted From: 98.212.104.155
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 29, 2009 - 8:53 am: | |
Wouldn't you love to catch someone in the act of doing that? Maybe it's better that I don't. |
don goldsmith (Bottomacher)
Registered Member Username: Bottomacher
Post Number: 261 Registered: 12-2000 Posted From: 72.152.137.134
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 29, 2009 - 9:23 am: | |
Methyl ethyl ketone is the best I have found to remove dried enamel; GOOD lacquer thinner (from a body supply dealer, not HD or Lowe's) is second. Good luck. |
John Jewett (Jayjay)
Registered Member Username: Jayjay
Post Number: 389 Registered: 1-2001 Posted From: 71.150.80.203
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 29, 2009 - 9:28 am: | |
MEK methyl ethyl ketone. Available at paint/ hardware /Lowe's H.D. Excellent paint stipper. ...JJ |
ED Hackenbruch (Shadowman)
Post Number: 154 Registered: 11-2003 Posted From: 70.192.187.132
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 29, 2009 - 9:49 am: | |
Toxic stuff though, try not to breath the fumes. |
Chuck Newman (Chuck_newman)
Post Number: 398 Registered: 1-2005 Posted From: 75.44.216.180
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 29, 2009 - 12:33 pm: | |
Absolutely. Wear a face respirator and rubber gloves when using a lot of that stuff. |
Mike Eades (Mike4905)
Post Number: 196 Registered: 12-2000 Posted From: 70.127.150.40
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 29, 2009 - 1:23 pm: | |
try oven off. It works on MC pin stripping. Mike |
Post Number: 280 Registered: 12-2000 Posted From: 24.164.20.23
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 29, 2009 - 3:21 pm: | |
"try oven off. It works on MC pin stripping. Mike" No, No, No,....The siding is aluminum, not stainless. Oven cleaner will eat it up. Len |
doug yes (Dougg)
Post Number: 98 Registered: 1-2007 Posted From: 174.131.122.226
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 29, 2009 - 6:55 pm: | |
Our first 4104, I recall chasing a rock thrower just before he broke a window. Eventually we replaced side windows with tinted Lexan. |
clint hunter (Truthhunter)
Post Number: 432 Registered: 1-2009 Posted From: 24.129.232.232
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 29, 2009 - 8:55 pm: | |
carb cleaner in a spary can and rags, removes it all, even after it has set up. ... where eye protection ... |
Roger Dalke (Roger_d)
Registered Member Username: Roger_d
Post Number: 21 Registered: 8-2007 Posted From: 205.206.150.9
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 30, 2009 - 11:56 am: | |
I have tried all of the above to remove graffiti, and all of them damage the stuff you don't want to! Then I stumbled across this "Graffiti Go" at Walmart. Most eco-friendly stuff doesn't work, but this does! We used it to remove graffiti on vinyl siding and it didn't affect the vinyl, and simply pressure washed off. www.ecosolveamericas.com good luck! Roger |
Post Number: 435 Registered: 1-2009 Posted From: 24.129.232.232
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 30, 2009 - 1:41 pm: | |
darn near anything that works will likely abrade the surface in the process of dissolving the grafitt0 pigments, and you may wish to amend that when your done.` ~ One thing I observed in the city , dealing with this often, remove it as soon as possible, before the next night, and when the young gafitti artists bring there buddies around to boast of there deed, you get to help them look like there full of crap to there the buds, and the problem self-remedies often. ~~ all markings are easier to remove in the first day before the paint or ink sets up & soaks in . ~~~Older stuff may also require steel wool or similar for abrasion on "porosus canvases" such as wood siding , concrete or brick. Got to love that Stainless Steel mci, IF ONLY you had used more of it then.~~~ >sure is funny watching this kind of nonsense on surveillance video in the course of "being responsible" for your own security. Seen a lot of crap & not much of was good crap like bus crap- >>IF ONLY not for those privacy laws, some of these moments in human stupidity would have made a fine & enlighting video for U-tube as to the motives for such behavior. >>>bus can't live with modern tech, nor live without<<< |
Post Number: 436 Registered: 1-2009 Posted From: 24.129.232.232
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 30, 2009 - 1:50 pm: | |
On real fresh graffiti, brake cleaner works if you catch it fresh enough, without much surface marking; use a soft rag and and catch the runoff as you flush with the brake cleaner aerosol. Something that should be on hand anyhow, next to the adhesive collection , as a prep cleaner before glueing. ... Always Protect yourself whole self well when using highly reactant toxins... |
Post Number: 281 Registered: 12-2000 Posted From: 24.164.20.23
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 30, 2009 - 3:04 pm: | |
I'm curious RJ, did you report it to the police? They may be able to identify the tagger. Never mind - I should learn to read the original post before saying anything. Len (Message edited by lsilva on August 30, 2009) |
Gary LaBombard (Garylee)
Registered Member Username: Garylee
Post Number: 206 Registered: 3-2004 Posted From: 64.12.116.203
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, August 31, 2009 - 4:14 pm: | |
You know, I think I will try to put a twist on this for me only. I think I will try find a group of young kids and inquire who of them is a good artist and see if they would be interested in painting some good graphics on our bus, (mine) that will be seen country wide when and if I ever get to travel. This should give them some sense of pride in showing off their talent instead of causing anger to someone that does not deserve it in the first place. I know,I know, I'm Naive!! I know I can't draw worth a hoot but some of these grafitti artist can. It may be a way of introducing them into a business that could be lucrative to them in the long run if they are interested. I agree in not wanting this to happen to me as it did RJ and also not sure of what my true actions would be if I caught someone doing that. I have a feeling I would need a lawyer, that is why I want to consider for myself now what I am mentioning here. I hope I still have this thought when ever I get to that point of graphics on the bus. It's worth considering to me if I was right now. Good Luck RJ, sorry again for your mess these guys or girls caused you. Gary |
Post Number: 447 Registered: 1-2009 Posted From: 24.129.232.219
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, August 31, 2009 - 6:19 pm: | |
98.7 % probability it was a "young she" that create this one , judging by the style and subject matter, most likely very early teens... the broken windows don't seem to be in keeping with the perpetrator though, must of been her younger sister getting bored with look-out duty. But that is just a rough guess based on a low quality picture... I was sure no-one want to know, so I though it appropriate to add this irrelevant info... ~the need to do 50 second parenting never ends~ |
Post Number: 1305 Registered: 5-2001 Posted From: 74.47.108.46
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 01, 2009 - 12:18 am: | |
Hi, RJ. I'm sorry to see that someone did a number on your coach. Have you had a chance to see if you can remove the grafiti, yet? I'm back in Kingman, again. The heat hasn't moderated much, yet. I've closed some deals that I will fill you in on when we get chance to visit. Sometime this winter, I think. Take care. Tom Caffrey PD4106-2576 Suncatcher Ketchikan, Alaska (Message edited by pvcces on September 01, 2009) |
Josh McElhiney (Zcommanager)
Registered Member Username: Zcommanager
Post Number: 49 Registered: 1-2009 Posted From: 75.187.41.177
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 06, 2009 - 9:49 pm: | |
RJ - I'm so sorry to see that the "Scum of the Earth" did this to your coach. My apologies for the late condolences, but I just made it back to the forum after a several month hiadus...Seeing this makes me want to 1) go check my coach right now - even thought it is in a "secure" storage facility with video survailance and 2) go check my lease agreement to see if I am "parking at my own risk" as well. Once again, so sorry for your troubles. :-( Josh |
