Need Injector C65 - Broke down in Val... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » March 2009 » Need Injector C65 - Broke down in Valdosta Ga. 2/28 « Previous Next »
Username: Pete_rtsdaytona
Post Number: 533
Posted From: 97.104.13.172
Posted on Saturday, February 28, 2009 - 8:22 pm:
Hi All
Just got a call from Randy - he was on his way here to Daytona for BIKE Week -
His GMC 5302 & 6v92ta with C65 injectors broke down - Stuck injector - causing wide open throttle
he's safely off the road at I75 ext 11 pilot truck stop
The STUCK INJECT (already removed) - appears to be a Reliabuilt C65 with a D/D 390 number on it - He needs the part
I've put him in touch with Greg Pagica ( http://www.cruiser-magazine.com/Help_assist_data_base.html ) -
Anybody have an injector for him now OVER THE WEEKEND
He can do the repair - he JUST NEEDS THE PART
It's raining in Ga. - 4 guys in the bus - and a trailer full of Harleys
Randy's cell# - ...262..498.7878...
(Message edited by pete rts/daytona on February 28, 2009)
Gary Pasternak (Cessna5354)
Username: Cessna5354
Post Number: 59
Posted From: 72.90.9.251
Posted on Sunday, March 01, 2009 - 7:00 am:
Pete it is great you are lending a hand here.
I have a couple of questions,
Does a stuck injector result in a loss in power ? Any other indications ?
I also assume that cylinder exhaust would be cold as well, but I would never think to look at that initially, I would be thinking dirty fuel filters.
Just trying to gain the knowledge that will assist me when I am in this situation.
Thanks much and enjoy the rainy Sunday ( eastcoast).
Post Number: 60
Posted on Sunday, March 01, 2009 - 7:02 am:
Also thinking albeit slowly today, The oil sump will be collecting this additional fuel, not good either.
Would this also be true?
Thanks guys.
Post Number: 534
Posted on Sunday, March 01, 2009 - 8:57 am:
IIRC - when an Injector fails - many times it hold the rack open (full throttle) ???
I'm not sure - perhaps someone else can enlighten us ??
frankdegroot (Coach)
Username: Coach
Post Number: 11
Posted From: 70.31.86.214
Posted on Sunday, March 01, 2009 - 8:58 am:
Hi Pete,
I have eight spare injectors for my 871.The # on them is 7E60 reliabit.If of any help let me know.
coach
Post Number: 535
Posted on Sunday, March 01, 2009 - 9:10 am:
Hi All
Randy has made it to Daytona - on his !!! 5V92TA !!!
Pulled in at 3:00 AM Sat Morning -
Then some SOB (ME) woke him at 9:AM to ask how he was doing (-: (-:
I'll fire up my classic '87 VT1100 Shadow MotorCycle and
We'll meet for breakfast Monday Morning -
anyone else here in Daytona for Bike week ??
Pete RTS/Daytona
P.S.
Hey guys - We could sure use more members
SIGN UP TODAY
( http://www.cruiser-magazine.com/Help_Assist_List.html
It's certainly working
SPECIAL THANKS TO DAVE & JAN SIEGAL -
They are the force that keeps this list going
Larry Nelson (Larryn4106)
Username: Larryn4106
Post Number: 17
Posted From: 173.22.183.74
Posted on Sunday, March 01, 2009 - 1:39 pm:
I had not even thought about carrying spare injectors. Sounds like it might be a good idea. Would one need to carry replacements for EACH injector (eight in my case)?
Username: Pvcces
Post Number: 1268
Posted From: 65.74.69.188
Posted on Sunday, March 01, 2009 - 11:47 pm:
Just one would be a big help in most emergencies.
Suncathcer
Ketchikan, Alaska
Post Number: 717
Posted From: 69.19.14.33
Posted on Monday, March 02, 2009 - 7:59 am:
THe other item needed will be the "pin" used to set the height of the injector.
There are at least 2 , so get the proper unit for your engine.
Only one injector is OK insurance , but a fist full of jumper tubing is also a good idea.
FF
Username: Coach
Post Number: 12
Posted on Monday, March 02, 2009 - 4:24 pm:
What would you need the jumper tubing for?
Username: Jackconrad
Post Number: 973
Posted From: 71.54.29.215
Posted on Monday, March 02, 2009 - 6:10 pm:
Fuel jumper tubing connects the injectors to the fuel supply. They are known to occasionally crack allowing diesel fuel into the oil. This is a "not good" situation. They can be changed easily after removing the valve cover. Jack
PS: If Jake brakes are installed, they require different fuel jumpers (to clear the Jake Brakes)
Username: Coach
Post Number: 13
Posted on Monday, March 02, 2009 - 6:30 pm:
I will be carrying a handfull of those.
coach
Username: Luvrbus
Post Number: 656
Posted From: 74.32.92.133
Posted on Monday, March 02, 2009 - 6:37 pm:
Coach, you don't need a hand full change over to the new style with the o rings they never break,leak and can be used over and over not like the 1 time lines of old good luck
