Denatured Alcohol/Electric stove Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » September 2002 » Denatured Alcohol/Electric stove « Previous Next »
R.C.Bishop (128.123.62.210)
Posted on Wednesday, September 18, 2002 - 11:48 pm:
FF, what can you tell us, pro and con, about the Origo stoves and their application in a coach? Seems like a way around propane.
Thanx.
FAST FRED (65.58.187.197)
Posted on Thursday, September 19, 2002 - 5:41 am:
The hassle with alcohol is Specific Heat, not many BTU per gallon.
That means that you must burn a huge volume to get much heat at the stove.
In the old days an alcohol stove had as many burner holes to deliver fuel as a propane one ,
and had to be hooked to a 10 gal pressurized tank to last a weekend.
And alcohol is expensive !!
Propane is FAR superior , as you can refrigerate , cook and have hot water and a furnace easily at low cost.
However if you wish to use an alternate fuel , kerosene (or mineral spirits) in a Primus burner works VERY well.
The Primus easily has 10,000 BTU on high and can boil a Big pot of water , or fry really well.
Downside is the burner MUST be pre heated with a squiret of alcohol (from an oil can) so there is a 30-45 second delay to start the stove.
I have used these in my sailboat and love it!!
The fuel usage is tiny 2 gal of Kero , 2 gal of Prime alcohol for 6 to 8 months of cruising.
A Primus burner full range with oven is avilable , but not cheap.
With over 7,000,000 RV's on the road all but 1/2% are propane , if there was a problem our "media" would have been screaming from the rooftops for 55 years .
Yes, a good propane instalation does take a bit of care ,
but if even overnight RV building companys dont have a problem ,
why would YOU?
RCBishop (128.123.62.201)
Posted on Thursday, September 19, 2002 - 10:28 am:
Thanx, Fred....and for the commercial.. :)
Peter (Sdibaja) (209.242.148.130)
Posted on Thursday, September 19, 2002 - 2:53 pm:
Alcohol also puts out lots of moisture, will fog you up big time, fast.
