Jim Gibson (River_rat)
Registered Member Username: River_rat
Post Number: 9 Registered: 1-2009 Posted From: 75.95.96.192
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 14, 2009 - 12:45 pm: | |
Here is a possible idea for a roof rack/deck. Remember I am a newbie to busses, so it might be impossible for some reason. Most racks are built as a separate structure, very expensive, highly engineered,, and attached at points to the roof by welding etc. In this configuration, all of the weight on the deck is on those points. What about a high-density foam filled rack where the weight is distributed over the whole deck area? I don’t have a sketch, but envision a flat deck of say ¾” marine plywood set on the roof so it touched the roof crown and went out about 6” less than the bus width. The distance on the outer sides from this wood deck to the bus roof would be about 4” to 5” at that point. Now envision ¼” aluminum diamond plate as sides, the top mating with the plywood, the bottom the bus roof. Along the front and back, the diamond plate would be cut to match the roof curve. The plate could be welded around it’s perimeter to form a seal to the bus roof, and the plywood attached with screws. If there are any air vents, even air conditioning units along the top, they can be removed and holes cut since they would only need an additional ¾” to be replaced. Those holes should be sealed. Once the structure is built, fill the entire “box” with rigid expanding foam, and now any weight on the deck is distributed over the entire roof. I suspect the foam, when expanded, will exert about 10-20lbs (?) of pressure so it should not bow or buckle the wood or the roof. I tried to use this description to get the concept across, but there are several obvious modifications, like adding plastic sheet in the box before the foam to keep the stuff off the roof, attaching the sides with screws, etc. One could make the entire structure of aluminum, no wood. I would place plastic sheet under the plywood so if the time came, it could be replaced and the foam would remain. Obviously the wood deck would want a weatherproof covering like one-piece rubber or really good exterior carpet, sealed from water. Rails could be easily attached. It would not be difficult to add a slight curve to the wood to water would drain off the edges. Lots of things would make it last a long time - and it’s dirt cheap! In my case, the beauty is being able to put in a roof access hatch from the inside the bus with a simple 6’ removable adder, as I never liked the idea of climbing from the ground all the way up on the outside - way too dangerous after a few cold ones! A boating deck hatch 24” squate with a ¼” tempered glass top can be had for a few hundred bucks, and they would easily install in one of the existing vent holes, with a bit of enlarging. Since there is only ¾” added to the installation height, and being able to put my roof vents back is a plus. Granted they would be in the center of the deck, but they would make a good “pass me another beer” port to the kitchen! I searched the archives and found nothing like this, so what do your folks think? Jim |
don goldsmith (Bottomacher)
Registered Member Username: Bottomacher
Post Number: 247 Registered: 12-2000 Posted From: 72.15.86.59
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 14, 2009 - 3:27 pm: | |
It'd be right tricky to weld aluminum plate to the roof skin, and distributing the weight over the entire roof would provide little support, since the skin is very thin and hardly structurally able to carry weight. It would probably work better to support the structure along the existing roof framing and rivet the joists to the framing. |
Cindy and John (Cindyandjohn)
Registered Member Username: Cindyandjohn
Post Number: 94 Registered: 1-2007 Posted From: 70.15.52.58
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 14, 2009 - 4:25 pm: | |
Jim, I have been in search of the right material to make a permanent roof deck on our Eagle. I have felt diamond plate would be too heavy... I found this material ( DuraGrid - http://www.strongwell.com/products/pultruded_prod/grating/index.shtml ) and have drafted a few ideas but the $1800 price has held me from making it... a sheet of this at approx 5' x 15' (I think i priced it at a 20' standard sheet)is 300 pounds. It is weather resistant and can have a skid resistant surface molded into it. it won't rot and it is very strong. I have seen it used as walkways to roller coasters in amusement parks. Of course it will need an understructure to mount it to the roof frame rails not the skins. I had planned to use some steel square tubing. My plan was to keep this as low profile as possible. I also agree there needs to be a safe ladder setup - I haven't come to that design yet. John |
Kasse Weikel (More_s_than_as)
Registered Member Username: More_s_than_as
Post Number: 14 Registered: 4-2009 Posted From: 71.84.122.200
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 14, 2009 - 5:35 pm: | |
i agree that the actual sheet metal skin wont hold much, and you should square off as much weight as possible on the frame up there. i was thinking of a similar idea, using the rear hatch to climb up to the deck. i figured a rope ladder under the hatch would be practical, space saving, and FUN! just roll it up when not in use. need clips and the bottom of the rope and eye loops/bolts on the floor to clip ladder bottom too (keeping the drunk people in mind here). some simple straps tacked to ceiling to tie knots around the rolled up ladder would hold it up and out of the way. a friend of mine recently got back from africa and was showing me pics of these "stretch tents" they have there. people have them out at burningman too, they are some crazy strong super stretchy material. if your put eye loops on the your deck rails, and clips on the edge of the stretch tent material, you can have a strong instant tent. just clip on and have a pole with a base to hold up the middle. the material is expensive however and the pole in the middle might get in the way. i didnt realize it at the time but we were going with the KISS method apparently. |
Sean Welsh (Sean)
Post Number: 821 Registered: 1-2003 Posted From: 67.142.130.14
![](http://www.busnut.com/bbs/messages/thumbnails/18178.jpg)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 14, 2009 - 7:01 pm: | |
We have a deck on our roof. It is supported at several locations that coincide with the internal roof truss structure of the coach, which is where you ultimately need to transfer the loads, even if you try to use the skin as support. Here are a pair of write-ups I did on the other board (in this thread):
quote:Quote from: H3Jim on March 13, 2008, 04:39:40 PM I suppose this request is primarily addresseed to Sean, since he's the only one I know with a roof deck. Now, see, as soon as you said that other decks came out of the woodwork... Quote Do you have any recommmendations for material / pattern? ... Having used your deck for sometime now, are you happy with the material and pattern you have, would you do something different next time? We're quite happy with what we have. But I'm sorry, I don't remember what it is (update - see next message, below). I basically gave Infinity a footprint for the deck, and they came up with the design, including materials. The deck is supported by four "feet" that have aluminum footpads to spread the load. Those feet are positioned above the two heavy box beams that run the length of my roof. The pads are bolted down (into riv-nuts), so the whole deck can be removed if necessary for maintenance or whatever (never, so far). Welded to the footpads are aluminum risers made of square tube perhaps 6" long or so, which let the whole deck clear the curve of the roof. Then there is a welded framework of aluminum square tubing, and above that the actual deck material. This is an aluminum extrusion, with multiple "I-beam" cross-section topped by perforated deck with non-skid knurling. It is made for the purpose. If you called Infinity and asked Jim or Danny they might be able to give you a manufacturer and product name (again, update -- it's below). It's worked so well, I would not go looking for anything different. In addition to being lightweight and sturdy, the perforations allow water to pass through, and the knurling makes for a non-slip surface. As a bonus, we can get the hooks of rubber truck-style bungees into the perforations to hold the el-cheapo lawn chairs we keep up there tight to the deck when traveling. Quote Do you have any comments on minimum load to provide for? I was thinking it didn't have to be too much, I only expect a few people plus a table and chairs up there. NO to mention i don't want to put too much strain on the roof itself. Our deck is roughly 7' x 7'. That's room for about four people, which I figure to be 250 lbs per each (a conservative number which allows for beefy guys, or jumping around, or more than four, etc.) for a total of say 1,000 lbs. I would guess our deck could probably hold nearly twice that, though. 1,000 lbs over 50 square feet is 20 psf -- I would say that's a good overall figure. Quote I was thinking lightweight, non slip but still comforable with bare feet, corrosion reisistent, easy to bolt down, easy to mount hinged railings on it. The stuff we used is all of the above, with the possible exception of the bare foot part. I do go up in my bare feet, but I feel the knurls and the perfs. The bare aluminum does stay quite cool though. Quote I suppose while I'm asking, any comments or suggestions on the railing? Good for safetly, but if someone tripos and lunges toward it, most of what I'm thinking about putting up would not hold a 200 pounder doing a header. We used Speed-Rail, I'm going to say 1" diameter. Easy to work, goes together in a snap. Using some aluminum round tubing just a hair larger than the Speed-Rail, Infinity made sleeves that the rails drop into, which are fastened to the deck frame. The holders are chamfered, notched, beveled, and slotted so the rail uprights remain attached permanently and fold up. then drop in. I would say the rail system would easily hold my theoretical 250-lb guy who's had one beer too many. Perhaps we need to post a video on the blog of how the deck sets up. In the meantime, the "overview" video clip in this post: http://ourodyssey.blogspot.com/2008/03/video-tour-of-odyssey.html has a short segment showing the deck. I know I have some photos of the deck framing and the deck itself, which I can upload if need be. Quote Of all the ladders I've seen, I like the kind that fold in the middle the best. I can store in in a bay, or even on top of the roof, and bring it down only when I want to use it. We use this one: http://www.campingworld.com/browse/skus/index.cfm/Outdoor-and-RV-Accessories/6-Compact-Fol ding-Step-Ladder/skunum=20318 (note that the photo shows a pair of back legs, but this model actually is a straight ladder with only one side). It was too long to store under our couch where we wanted it, so we cut one rung's worth off the top end. -Sean http://OurOdyssey.BlogSpot.com
and:
quote:Found it! Here's the stuff we used for the decking itself: http://www.slipnot.com/index.php?main_page=index&cPath=1_6_125 (not really -- see below) I see from this page that it comes in many widths, ours is made from 6" sections ("planks") and it is 1" thick. I seem to remember they got it in 10' or so lengths. Quote from: H3Jim on March 14, 2008, 05:10:04 AM Do you ever wish the deck was larger? Not really. You know, it's usually just the two of us, and that's plenty of space for anything we want to do up there. The couple of times we've had guests, it's been no problem to fit a couple more. The size, of course, was dictated by the amount of real estate we had left on the roof. We've got roof airs, plus the DataStorm dish. It did not make sense to extend it around the sides of an A/C. Frankly, if I had more available clear space up there, I'd put more solar on it, not more deck. -Sean http://OurOdyssey.BlogSpot.com
updated by:
quote:Quote from: Sean on March 14, 2008, 10:25:37 AM Here's the stuff we used for the decking itself: http://www.slipnot.com/index.php?main_page=index&cPath=1_6_125 Oops, wrong link. That's the same stuff, but coated with non-skid texture material. Our stuff is bare. Here's the right link (complete with cross-section and load tables): http://www.gratingpacific.com/aluminumgrating1.htm BTW, the Google search is "punched plank" and will turn up several suppliers. -Sean http://OurOdyssey.BlogSpot.com
and
quote:OK, largely as a result of this discussion, Louise made a video clip of the deck and its railing system. It's in this post: http://ourodyssey.blogspot.com/2008/03/small-space-saturday-roof-deck.html -Sean http://OurOdyssey.BlogSpot.com
(See, Ian, I'm trainable -- you've got me cutting-and-pasting all this stuff over here now. Hope you don't mind the direct link, though.) Hope this helps. -Sean http://OurOdyssey.BlogSpot.com (Message edited by Sean on April 14, 2009) |
Post Number: 11 Registered: 1-2009 Posted From: 75.95.96.192
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 14, 2009 - 9:34 pm: | |
Sean - that is the most beautifull vehicle I have ever seen! WOW. I watched all your videos - thank you for sharing that adventure in such a professional form! I'm going to let my wife see them, and although I run the risk of her thinking my little 4104 is inadequate, she will be able to see the possibilities! (to any of you who have not watched Seans videos, I highly recommend them) I love your deck, and the access port is what I was thinking. I already have one of those little fold up ladders - your's is the second one I have ever seen. I expect that the decking platform material is pretty pricy, although it looks perfect. In the "foam" method I am thinking about, I need a strong flat top that has no holes, as again, it is really just the top of a "box" that will be filled with rigid foam and the foam is the support. Does look mighty nice, and might end up the way to go... Cindy & John - I didn't realize that the diamond plate was that heavy - I guess that elimates it as a deck material, although if the stuff were just used for the 4 vertical ends and sides, weight would not be much of an issue. Might even be better to use 1/8" thick for the edges, as they are really only there to keep the foam in place, and it is the real support. On the roof stress issue again. If the deck were to be 7' X 25' - pretty good size, and we were to want it to hold 2000 lbs, that would work out to 175 Sq Ft of roof, or 11.5 Lbs/ Sq Ft. Seems like a pretty well distributed load. I am like Sean in that I really don't want a lot of people up there - just me and a few friends so 2000 lbs is maximum. I love the ideas folks - thanks! Jim |
Post Number: 18 Registered: 4-2009 Posted From: 71.84.122.200
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 14, 2009 - 9:53 pm: | |
my only concern is that the foam will not be "rigid" enough. i have used this expansion foam as well (not on the bus though) and its not concrete. I fear as time goes on the skins will buckle around the frame as the foam settles out from the weight. if the foam settles so much as a half an inch, it will also cause your cool side panels to buckle and the deck to sag (depending on deck materials). im planning on building a deck as well, but the same style as seans looks like the key. if you go ahead and do it your way, we could always compare and contrast later down the road, that would be fun, you never know you might be on to something there. at any rate if you ever need any help and can wait a few days for me to pop up, id love to come check out that BLUE SHAG CARPET before you rip it up. if its still in good condition and you dont want it can i have it for my geodome??? |
Post Number: 13 Registered: 1-2009 Posted From: 75.95.96.192
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 14, 2009 - 11:24 pm: | |
Kasse, I had not considered the foam sagging - that would be really bad. I'll do some checking into the specs. Blue shag - not pulling it for a while, but after I use it for a pattern, it's yours. Jim |
Patrick levenson (Zubzub)
Post Number: 80 Registered: 5-2007 Posted From: 70.29.209.208
![](http://www.busnut.com/bbs/messages/thumbnails/25135.jpg)
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 15, 2009 - 8:56 am: | |
the point that the roof supporting members are carrying the weight anyhow is worth considering. Even if the deck is supported over the entire area the supporting members are still bearing the weight. I'm inclined to think that the layer of foam is won't be that helpful, and if you get it wrong could bend the roof between ribs causing structural weakening. I have a 4104 and had thought that I would probably attach a deck at specific points on the roof, and use the stiffness of the deck help distribute the load over all the bearing points. (I alos like the idea of a deck I can remove easily). |
Post Number: 390 Registered: 8-2004 Posted From: 70.60.107.86
![](http://www.busnut.com/bbs/messages/thumbnails/19663.jpg)
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 15, 2009 - 9:05 am: | |
Patrick, I think your concern about structural weakening is a valid one. My bus is really tall and a previous owner had driven it into some overhanging tree limbs. The metal between some fo the supporting members had become stretched and pulled loose from its watertight joins. Took a lot of time and work to get it where it wouldn't leak. I think pressure on the sheet metal is a bad idea. |
Post Number: 142 Registered: 10-2006 Posted From: 71.239.202.82
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 15, 2009 - 12:22 pm: | |
We have a 21 ft roof deck that was installed by the converter. It is large enough and could be easily divided into 2 decks! The rails are SS and the deck is diamond plate. The ladder is also SS and brakes down into 3 pieces that are stowed in the basement. My wife is afraid of heights. I would be willing to trade it for whatever. Somewhere in the archives I posted a photo. If interested I could e-mail more and bigger photos. I have been told this feature set the original owner back PLENTY but, we have no use for it. We have an 85 Prevo XL it does not leak, it does not sag it has been up on the roof for almost 25 years now. (Message edited by Joe Camper on April 15, 2009) |
Post Number: 14 Registered: 1-2009 Posted From: 75.95.96.192
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 15, 2009 - 12:39 pm: | |
I talked with Dow Chemical this morning and they had no data on compressive strength, SOOOOO, maybe I heed the words of you more experienced BusNuts and don't take a chance on damaging my beautifull new toy... I love my bus! Still think it will work, but not going to take the risk! What a great site! Joe - just for grins, can you email me a photo of your unwanted deck... ####thinfilmguy@hotmail.com### Jim |
Post Number: 95 Registered: 1-2007 Posted From: 70.15.52.58
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 15, 2009 - 1:29 pm: | |
I think this is the link to the SS Roof Deck Photo from the past that Joe has... http://www.busnut.com/bbs/messages/233/19419.html John |
Roderick W. Chandler (Rod)
Post Number: 41 Registered: 11-2003 Posted From: 69.30.188.128
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 15, 2009 - 7:33 pm: | |
Jim you might try your idea on the ground on the patio or some such surface where you could walk around on it and see how well it held up. I doubt that the foam is made for supporting anything. Rod |
Post Number: 22 Registered: 4-2009 Posted From: 24.176.245.108
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 15, 2009 - 8:14 pm: | |
ok i know this is Jim's thread so im not trying to step on any tows or anything...but what exactly do YOU want as a trade? whatever implies a lot. do you want conversion specific items, or maybe something for your house or car (if your not a full timer). what value does it have to you right now, would a small cash offering do as well? you should definetly get first crack at the deal, but if you end up not doing it jim, pick me!! pick me!! pick me!! the edit : yeah i would be stoked to get that blue shag after yer done with it, maybe bring it out to the playa and we could tag there?!? (Message edited by More_s_than_as on April 15, 2009) |
Post Number: 143 Registered: 10-2006 Posted From: 71.239.202.82
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 17, 2009 - 3:57 am: | |
I have no awnings I would love to somehow be able to turn that deck into awning. I would take anything in trade I thought I could re-sell in a reasonable amount of time to then make that happen. I have my # on my personal profile. (Message edited by Joe Camper on April 17, 2009) |
