Hondo Joe MC5 (65.151.222.103)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 13, 2002 - 12:09 am: | |
My 8v71 is shutting down at 30psi. I assume the oil pressure switch may be at fault & I can jump across its terminals to bypass. Any tips? I disconnected air line to solenoid valve fuel shutdown & plugged air line to get it going today. Also "not generating" light is now on & is not charging. Are these two problems related? Need to fix it right as bus/rv will be for sale in the near future. Thanks for any ideas> Joe |
OLMoldy (208.18.102.217)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 13, 2002 - 10:43 am: | |
Pos in relay circuit, exp if your battery is real low it would not hold in the relay shutdown circuit. That is one way they are related. Larry |
MikeM (152.163.188.227)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 19, 2002 - 2:22 pm: | |
Could be the transmission oil pressure if you have a standard. Has a different pump than engine oil and usually doesnt have a gage attached. Oil pressure sending unit is above bell housing. You can install a "t" with a gage to see if this is the case. |
