Fuel advice to newbies, especially wi... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » April 2009 » Fuel advice to newbies, especially with auxiliary tanks! « Previous Next »
Glenn Williams (Glenn)
Username: Glenn
Post Number: 211
Posted From: 216.163.56.194
Posted on Sunday, April 26, 2009 - 11:15 pm:
I have never seen a post on this subject, but it is something every bus owner (especially newbies with older busses) should be prepared for! My MCI 7 has an aux fuel tank. Not long after I topped of my tanks for the first time, I developed a leak! My tank had corroded in several places in the bottom! So - now I'm leaking fuel, and I need to put 179 gallons of fuel somewhere! I burned up the phones looking for CLEAN 55 gal. drums that were used for something compatable with diesel. I found some, and didn't complain about paying a little for them either. Then I got busy with an el-cheapo electric fuel pump. That was memorial day of 08. Well, just under a year later, one of the hoses that connects my aux tank to the fuel lines that then attach to the main tank sprung a leak! Of COUSE I had just topped off the tank! Thank goodness I kept those barrels!
A note on keeping empty barrels - keep them upside down to keep water from standing on the lid and perhaps getting into the barrel. Occasionally drain them - like an air compressor they will build up condensation. You don't want to mix that with your fuel! Don't ask me how I know! That story is also called "how I learned all there is to know about fuel filters".
Username: Gusc
Post Number: 873
Posted From: 208.54.200.70
Posted on Sunday, April 26, 2009 - 11:28 pm:
Glenn,
If you really need to keep a big supply of diesel why not keep it in the barrels instead of the bus?
Clint Hunter (Truthhunter)
Username: Truthhunter
Post Number: 151
Posted From: 24.129.235.190
Posted on Monday, April 27, 2009 - 12:55 am:
why I gladly have a bus load of barrels of fuel & I'd know just what to do with them.
... Not as sure how well this modern diesel keeps, you know technology these days, great effort to make most things last less.
Ralph Peters (Ralph7)
Username: Ralph7
Post Number: 3
Posted From: 66.59.120.99
Posted on Monday, April 27, 2009 - 9:10 am:
Now I know I will not sell my 3 truck fuel tanks each hold 120 gallons plus. One will fit in the bay and it holds 122, so 3oo total gallons, now that's big $$$$$.
Username: Glenn
Post Number: 213
Posted on Monday, April 27, 2009 - 9:11 am:
Gus,
My head is a little fuzzy this morning and maybe I didn't write the first post as well as I should, but I meant that the purpose for having the barrels is not to store fuel long term, but to have a place to put fuel if you need to do a fuel tank/system repair. On the other hand, whend diesel was 1.87 this spring, I kinda wish I had filled the bus AND the barrels! :-)
Glenn
Post Number: 647
Posted From: 75.211.137.82
Posted on Monday, April 27, 2009 - 10:44 pm:
"Now I know I will not sell my 3 truck fuel tanks each hold 120 gallons plus. One will fit in the bay and it holds 122, so 3oo total gallons, now that's big $$$$$."
Also at the pump..........:-)
Username: Pvcces
Post Number: 1280
Posted From: 65.74.69.200
Posted on Tuesday, April 28, 2009 - 9:49 pm:
Leaning barrels so that water drains off before reaching either bung keeps rainwater out, too.
For what it's worth.
Suncatcher
Ketchikan, Alaska
Post Number: 154
Posted on Tuesday, April 28, 2009 - 10:13 pm:
...was really hoping to inspire some fact sharing on modern diesel such as "ultra-low sulphur" & the perishability factor "chemical stability wise" and maybe even how it pertains to both MUI and electronic inject engines.
