Tip for buying batteries! Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » April 2009 » Tip for buying batteries! « Previous Next »
macgyver (91flyer)
Username: 91flyer
Post Number: 361
Posted From: 74.193.225.134
Posted on Monday, April 27, 2009 - 4:55 am:
Hey guys... I went down to the local O'Reillies auto parts place looking for batteries and was let in on a little secret by one of the guys that I frequently buy parts from....
He said that *BRAND NEW* batteries, of any kind, regardless of the brand, type, voltage or size get SLASHED to only $20 if they sit on the shelf for too long. They call them "reconditioned" batteries...
Basically, they're just batteries that sat long enough to naturally lose a couple of volts and stuck on a charger... That's it. There's nothing wrong with them...
Most auto parts places are set up on a network that can check for these parts across all stores in the local area. Within a few seconds, they can tell you if there are any of these batteries available and where they are... And, in most cases, can have them delivered to your local store to pick up in one place by the next day or even a couple of hours!
Just thought I'd pass on the info.
Cheers!
-Mac
Username: Bigrigger
Post Number: 159
Posted From: 24.179.147.233
Posted on Monday, April 27, 2009 - 11:53 am:
Thanks for the info Mac, not only do I need batteries for my bus, but I need six new ones in my golf cart also, maybe I can save a bundle!
Clint Hunter (Truthhunter)
Username: Truthhunter
Post Number: 152
Posted From: 24.129.232.82
Posted on Monday, April 27, 2009 - 3:17 pm:
...might be good candidates for desulphating at $20, which is likely why they failed the load test and ended up on the reconditioned shelf. Using them in a battery bank would need them to be reconditioned to very similar states or you would have imbalance charge problems & very short life with low performance.
That is often the thing about secrets, they often tell less than the full truth.
Username: Pete_rtsdaytona
Post Number: 551
Posted From: 97.104.4.203
Posted on Monday, April 27, 2009 - 3:37 pm:
same is true for the INTERSTATE BATTERY DISTRIBUTOR - not the retailer - the DISTRBUTOR
They also only have a 30 day warranty
macgyver (91flyer)
Username: 91flyer
Post Number: 362
Posted on Monday, April 27, 2009 - 4:23 pm:
Well... Ya can believe they're the rejects if ya like... But, personally... $20 or less for a usable battery that's just been recharged seems like a deal to me! ^.^
-Mac
Username: Chessie4905
Post Number: 1421
Posted From: 71.58.110.9
Posted on Monday, April 27, 2009 - 4:49 pm:
If you want to go this route, you might want to look into Pulse chargers to desulfate them and chargers of this type are nice to use when coach is sitting for an extended time. Below is one of several companies that offer this equipment.
http://www.pulsetech.net/
Username: Niles500
Post Number: 917
Posted From: 173.78.29.189
Posted on Monday, April 27, 2009 - 5:37 pm:
For a lot less $$$$$ this might work - I use it - some time you can find them on sale for less - FWIW
http://www.batterymart.com/p-batteryminder-24v-1-2-4a-battery-charger.html
Username: Dmd
Post Number: 311
Posted From: 173.77.212.104
Posted on Monday, April 27, 2009 - 9:03 pm:
Last year i picked upa Black and Decker smart charger a BC40. It has 4/10/20/40 amp charge rates, has switch for wet,gel,AGM,batteries; 110amp engine start,and a desulfate and alt.check function. the best part is you can carry this thing with 2 fingers, it cant weigh more than 4 pounds. The desulfate worked on a old motercycle battery. I got it at Walmart (gotta buy somthing for the overnite parking privlage). One of our best buys in awhile.
Username: Pvcces
Post Number: 1281
Posted From: 65.74.69.200
Posted on Tuesday, April 28, 2009 - 10:07 pm:
We use desulfators all the time.
Sunctcher
Ketchikan, Alaska
Post Number: 654
Posted From: 75.211.121.125
Posted on Tuesday, April 28, 2009 - 10:25 pm:
Me, too....!
