Breast Plate "R" NFG Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » October 2002 » Breast Plate "R" NFG « Previous Next »
pipes (198.81.26.174)
Posted on Monday, October 21, 2002 - 11:28 am:
I am trying to mount a fiberglass breast plate (from U know who )
On My 69 05 Eagle,It ALMOST fits.The problem is, if I press it into one place it it pukes out at another place,I have cut it in two verticly in thc center,but still not a good fit.
My 05 is a 69 model is it possible that the wind shield area is more of the 01 style ?
if I can't make it fit PROPERLY are there any other Ideas?........ Thanks..... Ken. www.pipesusmc.net
riant (68.116.79.105)
Posted on Thursday, October 24, 2002 - 2:06 pm:
Ours was the same way had to cut and piece back together with fiberglass. If i hadn't it lookied like a big smiley face. if you have questions e-mail riant@charter.net
Posted on Friday, October 25, 2002 - 12:24 am:
Thanks RIANT... I Gave up on it.I put 1/4 inch wire mesh in a semi circle in between the 2 paralell tubing (Inside) and filled the space with spray foam leaving it recessed ( filed/rasp) about a 1/4 inch and will fill in with fiber glass mat to flush out side.
This way it will not interfere with the winshield rubber, foam is 3 inches thick, also acts as insulation and looks better too.... Ken 05 Eagle ... pipesusmc.net
Posted on Friday, October 25, 2002 - 12:48 am:
P.S to "breastplate"
The front of my bus is not skinned yet made it easy to do........
