High ampere solenoid Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » May 2009 » High ampere solenoid « Previous Next »
Bill Gerrie (Bill_gerrie)
Username: Bill_gerrie
Post Number: 258
Posted From: 216.198.139.38
Posted on Sunday, May 03, 2009 - 9:56 am:
Does anyone know a part number or store that sells a solenoid that I can use to boost the starting battery from the aux ones. It should have a capacity of around 500 amps. I have just installed a couple of group 31 starting batteries instead of the 8D's. The 8D's are too heavy to move around anymore. The aux batteries are on the same tray so it is easy to add a solenoid to join the two sets for boosting if needed. Thanks for any help.
Bill
Username: George_mc6
Post Number: 814
Posted From: 64.55.111.6
Posted on Sunday, May 03, 2009 - 10:44 am:
Bill,
A standard truck/bus starting solenoid is all you need. A 12 Volt starter may draw about 400 amps, while a 24 Volt will only draw about half of that. Then, the boost solenoid will only carry part of the starting load?
George
Username: Pete_rtsdaytona
Post Number: 552
Posted From: 97.104.12.208
Posted on Sunday, May 03, 2009 - 11:17 am:
Look for something with Silver contact
They will last the longest
Cole Hersee is a good name
or
400 amp Continuous
http://www.hydrogenappliances.com/solenoidrelay.html
400 amp - surge
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_391579_391579
1400 amp Price ??????
http://www.cmsquick.com/prod_17_SOL_01.html
multiple
http://www.thefind.com/garden/info-continuous-duty-solenoid
Info / catalog / no prics -->
http://www.veseysequipment.com/documents/files/Solenoids.pdf
(Message edited by pete RTS/daytona on May 03, 2009)
Chuck Newman (Chuck_newman)
Username: Chuck_newman
Post Number: 339
Posted From: 99.0.41.3
Posted on Sunday, May 03, 2009 - 1:43 pm:
Wow Pete,
The next time I can't find an electric part I need (and the associated link), it's obvious you're the man.
Bill, the CDS12/24 series have basically the same ratings of solenoids I purchased for three times the cost. And I thought I was getting a good deal at the time.
Gary Pasternak (Cessna5354)
Username: Cessna5354
Post Number: 67
Posted From: 71.255.24.84
Posted on Sunday, May 03, 2009 - 8:09 pm:
Chuck,
Are you still operating the bus OTR air system? If not you might salvage, as I did,frim your own bus, the 24V coil 200Amp contactors for the evap & blower motors. This is what I used.
Good Luck,
Gary
Post Number: 259
Posted on Sunday, May 03, 2009 - 11:12 pm:
Pete
Thanks for the replys. The listings you gave are great. I will order one tomorrow.
George
I figured that is how it would work. Thanks.
Chuck
I guess we should always ask Pete first before we order something. He is a wealth of knowledge.
Bill
james dean boggs (Jd_boggs)
Username: Jd_boggs
Post Number: 137
Posted From: 71.102.23.70
Posted on Sunday, May 03, 2009 - 11:39 pm:
One more.
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=4330015&MPN=EV200HAANA
