Peter River (Whitebus)
Post Number: 35 Registered: 4-2009 Posted From: 208.54.94.92
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 04, 2009 - 10:01 pm: | |
in my engine compartment, there is this mystery tank, about 12" in dia, 12" high. http://brightstoneriver.com/bus/IMAG0125.jpg http://brightstoneriver.com/bus/IMAG0126.jpg http://brightstoneriver.com/bus/IMAG0127.jpg there is a fill cap on top, with a little dipstick indicating it's full. there is a light amber oil (diesel?) inside. what is this thing, and why is it there? http://brightstoneriver.com/bus/IMAG0128.jpg http://brightstoneriver.com/bus/IMAG0129.jpg http://brightstoneriver.com/bus/IMAG0130.jpg bonus question: on the bus, seams connecting two metal panels are covered with this aluminum strip, that was affixed by aircraft type rivets. then it was covered with this long black (ugly on my white bus)rubber seal. why is this necessary, what does it do? Can I just rip it out, and if I can't, where can I get some white rubber seal to replace the black one? |
Tom Yaegle (Tom_5c)
Registered Member Username: Tom_5c
Post Number: 34 Registered: 1-2008 Posted From: 96.247.162.124
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 04, 2009 - 10:11 pm: | |
Power steering fluid tank? Also Hydraulic fan for rad, may use same pump and tank? Tom Y |
Post Number: 36 Registered: 4-2009 Posted From: 208.54.94.92
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 04, 2009 - 11:54 pm: | |
actually now that I think about it, you are probably right. the thing has engine in the rear and it was pretty far from the steering, so I didn't make the connection, but I don't know where else it could be. good answer, thanks! |
Sean Welsh (Sean)
Post Number: 841 Registered: 1-2003 Posted From: 64.194.66.108
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 05, 2009 - 1:55 am: | |
Looks just like my power steering reservoir. You top it up through the same hole as the dipstick, and there is probably a screen below that. My PS uses ATF, so it's red. Many units use 15W-40. -Sean http://OurOdyssey.BlogSpot.com |
Post Number: 228 Registered: 12-2000 Posted From: 24.164.20.23
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 05, 2009 - 8:30 am: | |
Looks like typical RV type seam cover. You can probably find white insert material at an RV supply. |
