Thermo King AC Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » May 2009 » Thermo King AC « Previous Next »
Peter River (Whitebus)
Username: Whitebus
Post Number: 38
Posted From: 204.62.111.51
Posted on Wednesday, May 06, 2009 - 1:31 pm:
my bus has this HUGE AC above the engine compartment. I figured since I am in the desert, it would be a good idea to keep a heavy duty AC system, but it does take up about 4' of room in the back.
does roof AC do enough to keep your bus cool? if you were in my shoes, would you rip out a perfectly working AC to gain 4' of space?
just brainstorming...
Username: Dnick85
Post Number: 297
Posted From: 76.124.92.192
Posted on Wednesday, May 06, 2009 - 4:00 pm:
Peter,
If you decide to rip it out, I'll take off your hands...
Redundency is KING! leave it alone and use it!
Nick-
Post Number: 758
Posted From: 208.100.193.1
Posted on Wednesday, May 06, 2009 - 4:03 pm:
Only you can decide if you do enough hours on the road to make the choice.
In the desert , if you ever shut off the engine and go camping, a swamp cooler might be enough , some will use so little DC a solar panel will keep them happy.
NO noisemaker , little sound and cheap,
Works for me,
FF
Username: Jackconrad
Post Number: 1051
Posted From: 71.3.157.139
Posted on Wednesday, May 06, 2009 - 5:57 pm:
One thing to consider when making your decision is "How much of the time you spend in the bus will the bus engine be running vs. how important is that 4' of space".
In our situation, the bus engine is running less than 5% of the time we are in the bus (we spend much more time camping than traveling) and the space was more valuable for other uses. YMMV, Jack
Username: Chessie4905
Post Number: 1441
Posted From: 71.58.110.9
Posted on Wednesday, May 06, 2009 - 6:08 pm:
Don't rip it out; carefully remove it. Since you have so little under floor space, that 5 feet is critical. You can rig up roof airs to do the same job and more.
doug yes (Dougg)
Username: Dougg
Post Number: 83
Posted From: 174.131.114.223
Posted on Wednesday, May 06, 2009 - 6:29 pm:
Maintaining the stock coach a/c is the largest expense for our fleet.
Username: Gusc
Post Number: 889
Posted From: 208.54.200.93
Posted on Wednesday, May 06, 2009 - 10:31 pm:
I agree with Nick, leave it in until you decide for sure you won't need it. It would be a disaster to remove it then find out you really need it.
The only downside I can see is having to run the engine so much.
You will need a minimum of three rooftops in the desert in the summer. I have two and they don't do the job even though my roof is padded and white. What I do is stay out of the desert in the middle of summer and out of the summer sun as much as possible.
Swamp coolers might do the job but it is a very hard job to cool a metal bus in the hot desert sun. Most buses are not very well insulated by the factory.
Post Number: 684
Posted From: 70.212.130.64
Posted on Wednesday, May 06, 2009 - 10:56 pm:
Amen and amen...forget the swamps...I use them in my house (Southern NM)...too much hassle, too much H2O, too much elec, too much pain.
Keep the on road. and figure a way to use it, if possible....generator?..power pole??? where there's a will....well, you know...
BTW...our Basement unit, if hooked to 50 amp does it just fine. I use it when I am working in the coach....(98 degrees here tomorrow) :-(
FWIW :-)
(Message edited by chuckllb on May 06, 2009)
Username: Whitebus
Post Number: 42
Posted From: 208.54.14.29
Posted on Wednesday, May 06, 2009 - 11:59 pm:
yeah, I figured I would let it lie... I had a bus mechanic offer me money so I could buy the roof air, but I guess I have to learn to live with it.
I can make cabinets to fit on the side of the AC unit. I don't know why there are so much wasted space in this vehicle...
