Who can do it? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » May 2009 » Who can do it? « Previous Next »
Larry Baird (Airhog)
Username: Airhog
Post Number: 152
Posted From: 209.79.85.124
Posted on Wednesday, May 06, 2009 - 6:53 pm:
I have a MC-7 that I just put a 8V-71T and a RTO in and I am happy with it but..... I have a new 740 complete just rebuilt and will be having my ankle fused in a few weeks so no clutching for me for 3 months. Does anyone know of someone that can make the swap and some one that wants to upgrade to a RTO with a new clutch setup? I am in So Cal area.
Larry
Glenn F Campbell (Gfcgfc1)
Username: Gfcgfc1
Post Number: 2
Posted From: 63.214.229.42
Posted on Wednesday, May 06, 2009 - 10:59 pm:
Hello Larry , good luck with your ankle! I also have a MC7 and am interested in the RTO !!! how many gears and what is the Overdrive ratio? Thanks so much for posting. Also did you ad a turbo to an 8v71N or is it a "turbo" engine? Thank you , Glenn
Username: Gfcgfc1
Post Number: 3
Posted on Wednesday, May 06, 2009 - 11:02 pm:
Jim Gibson (River_rat)
Username: River_rat
Post Number: 34
Posted From: 75.95.96.192
Posted on Thursday, May 07, 2009 - 9:30 am:
Hey Larry. I too have a very weak ankle, left over from a loosing battle with a car when I was a kid. I have a 4104 and the workout with the clutch is tough so I have been trying to understand pnuematic assist to make it less of a stress. Not simple - wish I had an automatic just for that reason! Good luck, and do what the Dr says! Do you suppose the conversion could be a medical expense...
Username: Airhog
Post Number: 153
Posted From: 173.58.244.205
Posted on Thursday, May 07, 2009 - 10:13 am:
Thanks for your replies and Glen the engine is a turbo motor that I had rebuild and made 342 hp on the dyno, wish it was inner cooled 400. The RTO is a 10 speed and is .8 in overdrive. I have 11R24.5 tires and it will run faster then you want to ride in it. I like the setup but I have a chance to get this 740 and if it doesn't work out for the change I will be happy anyway.
Ralph Peters (Ralph7)
Username: Ralph7
Post Number: 9
Posted From: 66.59.120.99
Posted on Thursday, May 07, 2009 - 11:27 am:
When you do the switch use a air cooler for the trans, my switch is soon in process from 8-71/740auto to 8-71T that does not have the oil cooler on engine for auto trans, so air is easy and simple. Also the cost and not having that heat in the rads. If you were in Pa. the shop that will be doing mine does this stuff, also shop rate is low $$.
Tom Christman (Tchristman)
Username: Tchristman
Post Number: 80
Posted From: 66.218.33.156
Posted on Friday, May 08, 2009 - 11:18 am:
I had my 13 spd to Allison HT740 switch done at Pedco in Santa Fe Springs, Ca. They are one of the few shops that I've run into that does work the way I would do it. After the installation, there was nothing I needed to do to it. The labor with air to oil cooler and installing the remote oil filter was about $6,000.00. Pricey, but I'm very pleased. Good Luck, TomC
Username: Chessie4905
Post Number: 1454
Posted From: 71.58.110.9
Posted on Friday, May 08, 2009 - 5:47 pm:
You know, you could get one of those auto shift Roadrangers; one you have to use the clutch to start out, the other one the clutch is electronically controlled; no clutch pedal necessary. Since you already have one, the adapting would be minimal. Or you could put an air clutch on what you have to lighten the pedal effort. Going from that Roadranger to an auto with no overdrive is going to be a real eyeopener in fuel consumption increase. 3 to 4 miles to the gallon possible.
David Guglielmetti (Daveg)
Username: Daveg
Post Number: 43
Posted From: 64.163.110.102
Posted on Friday, May 08, 2009 - 7:59 pm:
Forgive my ignorance, but when installing Fuller RoadRanger transmission, is the shift pattern the same or reversed?
Post Number: 1586
Posted From: 76.66.19.195
Posted on Friday, May 08, 2009 - 11:06 pm:
For shift pattern, it depends on what shift linkages you have, and how you adapt them to the transmission in question.
There are quite a few busnut installs that are shifting "backwards", but if that's your ride, you'll get used to it in a hurry!
Integrating some aspects of cab-over shift linkages to get the pattern "straightened out" have been successfully employed in some installs.
Post Number: 1460
Posted on Saturday, May 09, 2009 - 1:42 pm:
There is a remote shifter accessory version available that uses heavy Morse cables from slave to master controller to take care of that problem.
Username: Airhog
Post Number: 154
Posted on Saturday, May 09, 2009 - 2:36 pm:
Mine is backwards, but if you have never driven one the other way then it's forward. I only use the clutch to start anyway and the milage at 33,000 lbs pulling a 4,500 lb toad is 8+ mpg.
Username: Daveg
Post Number: 44
Posted on Saturday, May 09, 2009 - 3:57 pm:
So when using the remote shifter accessory with Morse cables...is there still "feel" when shifting, or is it the shove it and go?
What about the COE shift tower...any better for feel?
Post Number: 1462
Posted on Saturday, May 09, 2009 - 8:40 pm:
The feel is pretty much the same unless the cables aren't secured properly. Does give more flexibility in installation, plus, shift pattern can be opposite if desired. These cables are used for PTO and clutch controls in many applications, plus other uses and don't feel springy in those.
Username: Daveg
Post Number: 47
Posted on Saturday, May 09, 2009 - 10:14 pm:
Okay, so if I wanted to squirel away (sorry, archive) information on shift towers, manual trans set-ups etc, where is a good source? Transmissions I know, shift towers and asst. stuff to to avoid backasswards shift pattern I don't.
Username: Airhog
Post Number: 155
Posted on Sunday, May 10, 2009 - 10:04 am:
I used a 5 speed tower and rod with bearings, ran it down the center along with the air line, pyro and Jake wires. Covered the tunnel and made the floor level and made a insulated box under the bed for the turbo. I also had to make some changes to the clutch linkage and used a reducer on the bell housing
Username: Daveg
Post Number: 51
Posted From: 71.139.244.152
Posted on Monday, May 11, 2009 - 4:13 pm:
Larry, is that the answer to my question or something else?
Username: Airhog
Post Number: 156
Posted From: 71.102.2.43
Posted on Tuesday, May 12, 2009 - 2:58 am:
It's the answer I gave you, all the shifting parts are from a 72 Prevo.
Username: Daveg
Post Number: 54
Posted on Tuesday, May 12, 2009 - 10:01 pm:
Okay, thanks.
