Airfilters Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » June 2009 » Airfilters « Previous Next »
Username: Timb
Post Number: 314
Posted From: 66.165.176.62
Posted on Friday, May 08, 2009 - 10:45 am:
So with all the talk of K&N vs paper element in another thread what is everyone's opinion of the old oil bath style filter? Is there a good reason to get rid of it
Tom Christman (Tchristman)
Username: Tchristman
Post Number: 82
Posted From: 66.218.33.156
Posted on Friday, May 08, 2009 - 11:25 am:
If you have the original engine, have NOT turbo'd it, the oil bath filters work just fine. You should be servicing them at every engine oil change. The only reason they were changed to dry filters was the laziness of most in servicing the oil bath filters. Good Luck, TomC
Username: Timb
Post Number: 315
Posted on Friday, May 08, 2009 - 1:20 pm:
Thanks Tom. Just a 6-71 natural and I have always changed it when doing the crankcase I just never knew why they went away from them
Post Number: 766
Posted From: 76.250.203.186
Posted on Friday, May 08, 2009 - 3:19 pm:
The big downside to oil bath is good air velocity is needed.
So on that dusty campground road at 5mph BEHIND another camper , that cloud of dust you breath is what your engine gets , almost unfiltered.
FF
Username: Chessie4905
Post Number: 1452
Posted From: 71.58.110.9
Posted on Friday, May 08, 2009 - 5:28 pm:
Just another mess to deal with, just like the old style can oil filters and fuel filters. Less labor vs. more cost/ mess. At the price of oil anymore, air cartridge may be the way to go if you can get an air unit of sufficient size and the replacement element doesn't cost a fortune. You can check at a truck junk yard; they should go pretty cheap as long as you aren't looking for a chrome plated one OR get a take out bus filter assy. from NIMCO in New Jersey
Post Number: 1582
Posted From: 76.66.19.195
Posted on Friday, May 08, 2009 - 10:30 pm:
And a periodic really good cleaning of the entire oil bath assembly at some point, since you can be sure that some previous owner didn't do it right.
Complete dis-assembly, power wash or whatever the screens, and ensure proper oiling on re-assembly.
If you want to go paper element, the truck wrecking yard near you will have inexpensive options, or you may buy a new one from Donaldson for your application.
Jump the middle ages and get something that is secured by clips, the end of the canister is attached to the filter media, never mind the multiple bolts fasteners style, if you can avoid it.
JC Alacoque (Jc_alacoque)
Username: Jc_alacoque
Post Number: 81
Posted From: 72.45.68.242
Posted on Saturday, May 09, 2009 - 9:38 am:
I kept the oil bath filter even after I installed a turbo on my 4-71. I installed a filter minder gauge that told me it had about 15 inches water column restriction, within DD specs. And no the turbo wasn't pulling oil out of it like some young guys were telling me it would. I just replaced it with a dry filter housing out of a junk yard to go with my recent engine overhaul. I was looking for more air flow for better performance. Otherwise there is nothing wrong with oil bath. Servicing it isn't that bad either.
JC
Cullen Newsom (Cullennewsom)
Username: Cullennewsom
Post Number: 40
Posted From: 129.7.53.206
Posted on Tuesday, June 02, 2009 - 3:56 pm:
I just replaced my filter, it is a paper element. Cost was about a hundred bucks. I am thinking about replacing the air filter unit with one that is popular with trucks. I see advertisements for the elements as low as $30.00 for the el-cheapo filter elements. It's not that I want to run an el-cheapo air filter, but rather, due to economies of scale, more popular filters should cost less than unpopular ones. And they also have the advantage of being more widely available.
Username: Timb
Post Number: 345
Posted From: 74.244.14.221
Posted on Tuesday, June 02, 2009 - 5:55 pm:
Wow a gallon of oil for the bath seems pretty cheap in comparison to a paper element
Post Number: 50
Posted From: 98.201.161.214
Posted on Wednesday, June 03, 2009 - 11:00 am:
Yeah, they drive a hard bargain.
