Bill Holstein (Billmoocow)
Registered Member Username: Billmoocow
Post Number: 4 Registered: 5-2009 Posted From: 75.170.68.136
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 11, 2009 - 2:42 pm: | |
In my mci8 on the drivers side, there are two switches operated with left foot. One is the hi beam. The other one obviously operated with the heel of foot but looks just like a hi beam switch. I have looked everywhere in the manual and cant find what the switch operates. I clicked it and dont notice it doing anything? |
Skip N (Skip)
Registered Member Username: Skip
Post Number: 46 Registered: 11-2006 Posted From: 161.7.92.154
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 11, 2009 - 3:09 pm: | |
Bill Item P on page 3 of the operators man. Horn switch. Skip |
Post Number: 5 Registered: 5-2009 Posted From: 75.170.68.136
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 11, 2009 - 3:20 pm: | |
Thanks |
Post Number: 1592 Registered: 12-2000 Posted From: 76.66.16.242
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 11, 2009 - 11:03 pm: | |
The solution to the cryptic post: Heel operated air horn, or heel operated electric horn, depending on how the coach was optioned. There are two mounting positions for a toe activated switch, one for high beams, one for optional fog lights. A busnut with only high beams may find it convenient to move the high beam switch to the other mounting hole. More foot room, less likely to activate by mistake. happy coaching! buswarrior |
Post Number: 8 Registered: 5-2009 Posted From: 98.232.218.68
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 11, 2009 - 11:30 pm: | |
My electric horn switch is on the steering wheel. You push with da finger. |
Post Number: 1595 Registered: 12-2000 Posted From: 76.66.16.242
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 11, 2009 - 11:34 pm: | |
And if the heel switch looks just like a high beam switch, it powers the same electric horns that the steering wheel switches do. the air horn button has a bit of a rubber donut around it. happy coaching! buswarrior |
John Lacey (Junkman42)
Registered Member Username: Junkman42
Post Number: 78 Registered: 3-2007 Posted From: 69.19.14.16
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 12, 2009 - 12:32 am: | |
Bill, My MC7 has two switches operated like Yours and one is for the retarder! Is it possible You have a retarder? Regards, John |
Post Number: 9 Registered: 5-2009 Posted From: 98.232.218.68
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 12, 2009 - 12:54 am: | |
Well, right now i feel retarder. How would it operate? |
Post Number: 1060 Registered: 12-2000 Posted From: 71.3.157.139
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 12, 2009 - 8:09 am: | |
If it is a retarder, applying it while coasting with no throttle application, you will feel the bus slowing much more quickly. Jack |
Post Number: 11 Registered: 5-2009 Posted From: 98.232.218.68
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 12, 2009 - 12:04 pm: | |
I will try that. |
Post Number: 79 Registered: 3-2007 Posted From: 66.82.9.58
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 12, 2009 - 1:03 pm: | |
Bill, I should have also mentioned that I have a telltale light in the light cluster that says retarder and it comes on with retarder application! The retarder will not come on below about 20 MPH. Regards ,John |
Post Number: 14 Registered: 5-2009 Posted From: 98.232.218.68
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 12, 2009 - 1:10 pm: | |
Thanks. I do have one light i cant read. bottom row 2nd from left and next to that the retader light. awsome! What is the light 2nd from left? |
Post Number: 20 Registered: 5-2009 Posted From: 98.232.218.68
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 17, 2009 - 2:55 am: | |
Come on! Its the only light i cant read. Anyone? |
