Luggage compartment door Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » May 2009 » Luggage compartment door « Previous Next »
Peter River (Whitebus)
Username: Whitebus
Post Number: 78
Posted From: 208.54.14.22
Posted on Wednesday, May 27, 2009 - 2:11 am:
thank god (and Ian) that I have this forum full of bus owners to ask these questions...
ok, one of my luggage compartment door (that swing up, like greyhound buses) is having a problem.
I have 4 doors, and this is the only one that's misbehaving. I tried comparing the hardware, and I can't tell how to adjust these.
I have 3 pix.
http://brightstoneriver.com/bus/DSCI0792.jpg
this is how the doors open up. the top shiny arms are the ones that bears the weight, and smaller, lower rusty arm is the one that keep the door vertical. the are 2 top arms, and one lower ones, for each door. this picture is with door partially deployed.
http://brightstoneriver.com/bus/DSCI0793.jpg
this shows the top of the lower arm, along with a bar that the door latch onto.
http://brightstoneriver.com/bus/DSCI0794.jpg
this door when closed, doesn't align right. the other doors are not like this one.
each arm has an adjustment screws. Top arm has screws, but I have to unscrew it off the door, and I don't want to mess it up even more. the lower arm has a screw that I can adjust.
what do I do to make the bottom of the door align again? which screw do I have to tighten/loosen?
I figure someone here had this problem before.
(Message edited by WhiteBus on May 27, 2009)
Austin Scott Davis (Zimtok)
Username: Zimtok
Post Number: 328
Posted From: 216.37.73.226
Posted on Wednesday, May 27, 2009 - 9:37 am:
If it were me trying to figure out the geometry of the adjustments I would look at it from the inside when the door is closed. It should be easier to identify which adjustment point you need to adjust to get the door to close tighter.
Based on the photos and trying to visualize what is where when the door is closed I would guess that the bent tubular arm is the one you need to adjust.
Username: Timb
Post Number: 335
Posted From: 66.165.176.62
Posted on Wednesday, May 27, 2009 - 10:10 am:
I would be a little leary of making that recomendation without knowing what type of latches he has or at least have a helper nearby that can open if you get stuck
Username: Whitebus
Post Number: 79
Posted From: 204.62.111.51
Posted on Wednesday, May 27, 2009 - 2:34 pm:
interesting...
it's barely latching as it is. I can open up the other doors before crawling in I guess.
Skip N (Skip)
Username: Skip
Post Number: 47
Posted From: 161.7.89.205
Posted on Wednesday, May 27, 2009 - 3:23 pm:
FWIW.......
If it were me :-) Rent a sheet rock jack to
hold it in place. Put some blankets on it
so as not to scratch. Once the jack is adjusted
to hold it in place. adjust both top and bottom.
by the looks the small arm more than the big one.
Repeat until it is where you want it.
Skip
Username: Chessie4905
Post Number: 1482
Posted From: 71.58.110.9
Posted on Wednesday, May 27, 2009 - 4:38 pm:
Did you ever get a shop manual for this coach? You need to get one if you haven't I don't think there is much familiarity here on this model. I could be wrong though.
Username: Whitebus
Post Number: 80
Posted on Wednesday, May 27, 2009 - 4:50 pm:
nope, searched long and hard, but the company went belly up in 1998 (mine was probably last one built)...
I thought the component is pretty much the same across the board. I see other buses with similar door mechanism all the time. I was hoping someone with the same mechanism had the same problem, who can steer me to the right direction.
Glen Rice (Rgrauto)
Username: Rgrauto
Post Number: 4
Posted From: 98.18.110.59
Posted on Wednesday, May 27, 2009 - 9:48 pm:
Whitebus, I think you may need to shorten the lower link to pull the door in. Be sure to measure the length of the rod before you adjust so you can put it back if that does not help.
Glen
Username: Zimtok
Post Number: 329
Posted on Thursday, May 28, 2009 - 9:21 am:
Wouldn't the lower link be vertical when the door is closed? If it is vertical when closed, adjusting it would adjust the door up or down depending on whether you lengthened or shortened the link.
The curved tubular arm looks like it would be horizontal at the end that attaches to the door. that is why I suggested to adjust it to pull the door in tighter to the bus.
I figured if he emptied his compartment he could close this door and open the other side to see how the arms are orientated when the door is closed.
Username: Timb
Post Number: 339
Posted on Thursday, May 28, 2009 - 10:21 am:
Austin I agree that is a great idea I was just trying to caution since some people might not see the common sense solution of opening the other side :-)
No insult intended to anyone but crap happens
Username: Whitebus
Post Number: 84
Posted on Thursday, May 28, 2009 - 4:46 pm:
austin, yes it's vertical when closed.
I fear that it might be a combination of the two, tightening the top bar and loosening the other....
Username: Zimtok
Post Number: 330
Posted on Friday, May 29, 2009 - 9:14 am:
Tim,
You were correct in pointing out the possible dangers of my suggestion. I have a tendency to dismiss/overlook these things assuming that it did not need to be said. (my bad) I do not take offence to anyone adding to my comment or correcting me.
Peter,
I think that no matter what, it will be a "trial and error" to get the right combination that will work. Once you have it figured out post it for the benefit of others.
Karl VanShellenbeck (Kvan)
Username: Kvan
Post Number: 37
Posted From: 66.68.82.97
Posted on Friday, May 29, 2009 - 9:35 am:
From the pictures it looks like the upper part of the door is closing at the proper distance. If so, it seems as though the lower small arm needs to be shortened slightly to bring the bottom portion of the door in slightly. Good luck
Keith Wood (Ft6)
Username: Ft6
Post Number: 118
Posted From: 75.211.94.138
Posted on Friday, May 29, 2009 - 10:22 am:
This is what's called a "Pantograph" mechanism.
Here is what I would do.
1) MEASURE the clearance at top and bottom, front and rear corners, INCLUDING vertical alignment.
2) LENGTHEN top and bottom rods by 1/4".
3) Measure again. What has changed? For instance, the door may have moved upward.
4) Now move one set of adjustments OUT another 1/4" and measure again. Now you see what's moving what, and which direction. Until you understand that, you don't want to be moving things in where they can bind. Once you DO know it, you can fit the adjustment.
Username: Kvan
Post Number: 38
Posted on Friday, May 29, 2009 - 12:56 pm:
Looking at the pictures of the adjuster rods, isn't the lower rod rusty in all places except the end. Does it look like the lower rod has been lengthened? Just an observation.
Username: Whitebus
Post Number: 85
Posted on Friday, May 29, 2009 - 1:12 pm:
karl, when I got the bus, I WD40'd most joints and connectors and maybe it got this link too loose.
interesting.
Username: Kvan
Post Number: 39
Posted on Friday, May 29, 2009 - 4:20 pm:
Are the lock nuts tight on that lower rod? Is the door spaced out the same distance at the bottom on both sides? Based on what I see I would shorten that lower arm slightly and see if it improves.
Username: Whitebus
Post Number: 88
Posted From: 208.54.14.122
Posted on Friday, May 29, 2009 - 10:26 pm:
thank you for your insight.
It was the lower bar, and I finally found out the reason.
the top lock nut on the lower rod, when door was fully deployed was interfering with the door latch bar. I found to my amazement that everytime that the door was opened fully, the latch bar would turn the lock nut 1/4 turn. That's why over the year, it looked more and more out of alignment.
I loosened the lock nuts, both top and bottom, and rotated the bar, tightening the lower rod about 1/4 inch, and the door is now lined up perfectly. I will put some spacers to prevent the interference.
Thanks everyone for your help!
Username: Kvan
Post Number: 40
Posted on Saturday, May 30, 2009 - 12:05 am:
Glad you got it fixed.
Username: Jackconrad
Post Number: 1103
Posted From: 71.3.157.139
Posted on Saturday, May 30, 2009 - 7:12 am:
Thanks for posting the solution. It is always nice to know how a problem was resolved. Jack
