Post Number: 502 Registered: 3-2007 Posted From: 71.55.197.237
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, June 04, 2009 - 10:15 pm: | |
I have tried to find the replacments for the torsion system on the 4905 baggage doors and NO one at the sites I have know what I am talking about, can you help as I am going to replace the hinges and those at the same time. If part numbers are available I need that and maybe set-up info. Thanks Gomer |
Post Number: 781 Registered: 7-2006 Posted From: 75.210.202.4
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, June 04, 2009 - 10:44 pm: | |
Marvin... you can problbly get them from AustinHardware.com They will give you a "form"...fill it out...they will then send you a schematic of what you need. All by Email. From my experience, I would fudge a bit on the "weight" of the door...ie.. if it is 25 pounds...make it 50. That will give you more "bite" and will hold the door at the level you want it to be. (over your head at an extreme angle, preferably)... As you know, they will "wear out" in time, and the "xtra" will provide a bit of insurance. HTH RCB |
FloridaCliff (Floridacracker)
Registered Member Username: Floridacracker
Post Number: 403 Registered: 7-2004 Posted From: 97.101.146.143
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 05, 2009 - 8:42 am: | |
Marvin, I have the numbers at home. I will post this evening if not already answered.. Cliff |
Post Number: 504 Registered: 3-2007 Posted From: 71.55.197.237
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 05, 2009 - 11:01 am: | |
Thanks I will let you know if they send me anything. They did confirm they received the mail tho. gomer |
Post Number: 404 Registered: 7-2004 Posted From: 24.27.226.231
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 05, 2009 - 10:38 pm: | |
Gomer, Tokico, Y3029 I don't remember who I bought them from, but you can use that number to cross reference to another supplier if needed. Cliff |
Post Number: 508 Registered: 3-2007 Posted From: 71.55.197.237
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 05, 2009 - 11:13 pm: | |
thanks Cliff, I will check it out. Gomer |
Steve Kolb (Skolbibp)
Registered Member Username: Skolbibp
Post Number: 1 Registered: 6-2009 Posted From: 70.46.31.2
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 08, 2009 - 9:40 am: | |
Marvin, IBP can also supply the props Steve |
