Chuck Newman (Chuck_newman)
Post Number: 369 Registered: 1-2005 Posted From: 99.0.41.3
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 15, 2009 - 8:35 pm: | |
Having trouble finding a 3" dual Y bayonet adapter. It would look like the one in the photo, except I need 3" pipe and flange on both inlets instead of the 1-1/2". Aluminum or stainless preferred, but I'll take ABS if that's all that is available. Any ideas on sources? Thanks.
Post Number: 262 Registered: 12-2000 Posted From: 24.164.20.23
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 15, 2009 - 9:43 pm: | |
It looks like you may have to cobble one up using Valterra T1039-1 and T1029-2 http://www.valterra.com/ |
Mark Morgan (Stormcloud)
Registered Member Username: Stormcloud
Post Number: 7 Registered: 9-2008 Posted From: 216.36.185.40
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 15, 2009 - 11:14 pm: | |
That looks amusingly like the 'adapter' that Robin Williams used in the movie 'RV' when he was dumping the black tank.... Hope you find what you need. Regards. Mark |
Sean Welsh (Sean)
Post Number: 897 Registered: 1-2003 Posted From: 72.171.0.149
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 15, 2009 - 11:24 pm: | |
Chuck, FWIW, I think a Valterra T1039 (no suffix) is what you want. Any Valterra dealer, including Camping World, should be able to order it. We have 3" valves on both tanks (and another 3" valve downstream of the "T"), and we had to use the individual parts coupled with standard ABS plumbing fittings. We used a "sanitary T." I'm pretty sure we ordered the individual Valterra parts from CW. HTH, -Sean http://OurOdyssey.BlogSpot.com (Message edited by Sean on June 15, 2009) |
Post Number: 370 Registered: 1-2005 Posted From: 99.0.41.3
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 16, 2009 - 12:25 am: | |
Thank you Sean. The T1039 is exactly what I need. Several places carry and have photos of the T1036 above, but the T1039 was not displayed during numerous searches. Interestingly the Valterra catalog pdf was of no help. But http://www.valterra.com/RV/flanged_valve_fittings.htm show all fittings by number. Since I've decided to use the Drain Master electric waste valve it appeared pointless to buy 1-1/2" bushings and fittings for the gray tank with the net result of restricting the flow. Thanks. |
