Exhaust - off the manifold - 73 silve... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » June 2009 » Exhaust - off the manifold - 73 silver eagle-05 « Previous Next »
Micheal Razberry (Razman)
Username: Razman
Post Number: 4
Posted From: 70.66.128.211
Posted on Tuesday, June 16, 2009 - 8:58 pm:
Hello
It looks like the exhaust pipe coming off the manifold needs to be replaced. The top side fitting into the manifold comes out a couple inches and then 45`s straight down for about 12 inches to a flange which joins another flange and then 45`s down to the muffler. Its the upper pipe which is toasted at the flange.
Does this make any sense to you`all? The walls on the pipe are rather thin, so I doubt it would take a weld, wouldn`t last.
Anyone up here in BC CANADA that can suggest where I might get a part like this?
Has anyone used that flex pipe ... what would the life on it be?
thanks, razman
Username: Luvrbus
Post Number: 706
Posted From: 74.33.63.151
Posted on Tuesday, June 16, 2009 - 10:19 pm:
Razman, the orginal pipe on the model 05 was a cast 90 with a steel flange welded into it and was easy to repair the flanges are a stock item at most muffler shops .If the cast 90 has been replaced go to a muffler shop and have a steel 90 made.I just gave a cast 1 away 2 weeks ago good luck
(Message edited by luvrbus on June 16, 2009)
Username: Chessie4905
Post Number: 1527
Posted From: 71.58.110.9
Posted on Wednesday, June 17, 2009 - 4:57 pm:
Those metal flange stubs are listed in the local NAPA heavy duty exhaust catalog if you have trouble finding a stub.
