671TA in 04 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » December 2002 » 671TA in 04 « Previous Next »
bud 4104-4104 (24.69.161.104)
Posted on Monday, November 25, 2002 - 11:19 pm:
has anyone installed a 671TA into a 04 what kinda problem can i look for
RJ Long (24.127.74.29)
Posted on Monday, November 25, 2002 - 11:49 pm:
Bud -
TTBOMK, Detroit never built the 6-71 with an aftercooler for the turbo models, which would make it a "6-71TA" like you posted. Only 6-71Ts were available.
It's a good swap into a 4104, but make sure you get a LH engine, otherwise you'll end up with four speeds in reverse and one go forward! Also, you cannot just slap a turbo on a non-turbo engine - there are quite a few internal differences between them.
The turbo will have to be relocated within the engine compartment, there isn't enough clearance in the stock configuration. Most folk mount it over the transmission on custom brackets.
The only other real concern is cooling. You'll have to make sure the cooling system is in excellent condition, and possibly replace the radiator with a thicker-cored unit.
This gives performance similar to a stock 4106, except for top speed, that's hampered by the different bevel gear ratio in the V-drive.
HTH,
RJ
PD4106-2784
Fresno CA
Geoff (64.1.0.236)
Posted on Tuesday, November 26, 2002 - 10:44 am:
Randy at Just Buses in Arizona was selling some LH 300 HP 6-71TA's that he took out of some buses. He may have even installed one for someone. Give him a call at 623 341 1942 and ask him about installing one in a 4104.
