Good Bus repair in El Paso or Tucson Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » December 2002 » Good Bus repair in El Paso or Tucson « Previous Next »
john marbury (Jmarbury) (65.100.118.38)
Posted on Sunday, December 01, 2002 - 11:56 am:
This following message was sent to me. However, I live in Gallup NM. which is 300 mi. from Demming. If there are any Bus-nuts in or around El Paso or Tucson thet know of a compotent repair shop, could you please forward that info to: mrclick@bellsouth.net
"Hi john thank you for the phone number, I will call you later to day an explain ,my name is Rick young I live in Louisville KY,I am trying to buy a mci7 bus that is broke down in Deming NM, the man that ones it was driving it to Cal from Fla the clutch started to slip in 4 gear on flat ground an 3 gear on hills, I will buy it if I can find a shop to fix it. That is what I needed from you, do you know a good shop to fix it the bus it is still drive able he said ,My problem is I can fly down an take it to a shop but just in case they cant fix it in two or three days I need a storage place for it till I can get back thank you, Rick young.
R.C.Bishop (128.123.221.201)
Posted on Sunday, December 01, 2002 - 6:37 pm:
Sent him an email with some, hopefully, helpful information. RCB, Las Cruces, NM :)
