How much coolant in a MCI 102a3 8v92? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » August 2009 » How much coolant in a MCI 102a3 8v92? « Previous Next »
hojji firemaker (Hojjifiremaker)
Username: Hojjifiremaker
Post Number: 22
Posted From: 67.142.162.33
Posted on Friday, August 21, 2009 - 11:58 am:
I had a leak in my coolant line when I purchased my bus... I repaired the leak, but now have to add coolant... I bought 6 gallons of FLEET CHARGE brand coolant for diesel motors, and added 6 gallons of distilled water to it to dilute... I am checking the level marker between the radiators, and still no sign of enough... how much is the total fluid capacity of my motor?
Thank you!
clint hunter (Truthhunter)
Username: Truthhunter
Post Number: 395
Posted From: 24.129.232.219
Posted on Friday, August 21, 2009 - 1:48 pm:
if you overfill , after bleeding the air out, just drain some off with on of the bleed screws (the thermostat housing makes a good location on the 8V71, {just stick a hose on right-back into your jug})
-until the level in the sight glass (middle of the coolant reservoir)is half way and your done, I use a blue led flashlight to see through the dirty sight glass (as coolant shows up well in blue "monochromatic" light as does diesel}). Just don't get your arm caught in the blower belt , if your dangerous enough to do this while the "jimmie is roaring".
...keep on safe bus wrenching; cool-ly...
Rob Norgren (Robsedona)
Username: Robsedona
Post Number: 60
Posted From: 75.210.248.70
Posted on Friday, August 21, 2009 - 3:48 pm:
I can tell you My mc5a is 52 gal. I believe the 9 has more and I think the 102 is the same as the 9.
You have coolant going all the way to the fount of the coach.
Post Number: 396
Posted on Friday, August 21, 2009 - 4:04 pm:
and who knows what aftermarket modifications have been done on these old dogs, so factory specs. are just a rule of dumb, those "four bolts" are always the final word in a adequate repair.
Roy Childs (Rchilds)
Username: Rchilds
Post Number: 11
Posted From: 142.161.152.16
Posted on Friday, August 21, 2009 - 4:34 pm:
The book I have says 24 US gal. is the capacity.
Post Number: 23
Posted From: 67.142.162.32
Posted on Friday, August 21, 2009 - 6:38 pm:
well, 24 and 52 gallons is a very big difference... I got allot more today, so I'll find out soon... Thanks everyone!
Username: John_mc9
Post Number: 972
Posted From: 74.162.95.136
Posted on Friday, August 21, 2009 - 7:50 pm:
Re:
"how much is the total fluid capacity of my motor?"
Keep in mind, that you're not just filling the engine, you have to fill
and bleed the entire system, front to rear.
http://www.fantiques.com/web_rental_1-22-09/1549/bus_info/
Username: Joemc7ab
Post Number: 360
Posted From: 66.38.159.33
Posted on Tuesday, August 25, 2009 - 1:24 am:
According to DA BOOK the cooling system capacity of the 8v92 (cylinder block, heads, thermostat housings and oil cooler housing) is 7 1/4 gallons or 27.4 liters for us canuckies. Sec 5 Page3
Joe.
Username: Robsedona
Post Number: 62
Posted From: 70.212.150.35
Posted on Tuesday, August 25, 2009 - 7:54 pm:
I talked to MCI today and he said 24 1/2 Imp gal and 30 1/2 US gal. total that is if all systems are still in place.
Cullen Newsom (Cullennewsom)
Username: Cullennewsom
Post Number: 132
Posted From: 98.201.161.214
Posted on Thursday, August 27, 2009 - 9:32 am:
Helpful firefox extension for downloading multiple images.
http://www.downthemall.net/
