Polishing paint ? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » September 2009 » Polishing paint ? « Previous Next »
doug yes (Dougg)
Username: Dougg
Post Number: 94
Posted From: 174.131.122.226
Posted on Monday, August 24, 2009 - 9:53 pm:
The paint on this MCI is only 6 years old and it has lost all its gloss. Maybe it went through a truck wash with the acid spray on. Can it be polished back to a good shine or should I plan for a new paint job?
David Guglielmetti (Daveg)
Username: Daveg
Post Number: 104
Posted From: 70.237.15.50
Posted on Monday, August 24, 2009 - 10:08 pm:
Can you find out who painted it and what brand/type of paint was used?
Username: Jackconrad
Post Number: 1155
Posted From: 72.57.239.169
Posted on Tuesday, August 25, 2009 - 8:38 am:
I would try some red or white(finer) polishing compound, available at any auto parts store in the polsh/wax department, by hand in a small inconspicuous spot to see what happens
(Message edited by JackConrad on August 25, 2009)
Username: Luvrbus
Post Number: 755
Posted From: 74.33.54.207
Posted on Tuesday, August 25, 2009 - 10:55 am:
Perfect-it 3000 extra cut compound by 3M with a sponge buffer will do the job for cost about 40 bucks a qt
Cullen Newsom (Cullennewsom)
Username: Cullennewsom
Post Number: 136
Posted From: 98.200.242.221
Posted on Friday, September 18, 2009 - 1:08 pm:
1. Strip any wax.
2. Polish it with "Compound" - there are several grades, pick the one that you need, or try several steps using a finer grade (grit size) each time. On such a big job it will pay you to discover the one which gives the best result.
3. It might be cheaper by the gallon.
4. Wax it when you're done.
