Is there a way to install a ladder on... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » August 2009 » Is there a way to install a ladder on the back of a MCI? « Previous Next »
hojji firemaker (Hojjifiremaker)
Username: Hojjifiremaker
Post Number: 24
Posted From: 67.142.162.35
Posted on Tuesday, August 25, 2009 - 12:16 pm:
I really want to put a roof access ladder on the back of my MCI 102a3, but the engine/radiator bay door prevent me from doing the standard traditional mounting...
I have considered a split ladder, but think it may be too weak, especially if sections of it are connected to only the thin metal doors... A folding one would be good perhaps, if it folded up high enough... Connecting to the roof seems like the only really sound place to mount it... Any ideas? someone must have done it by now...
Username: John_mc9
Post Number: 974
Posted From: 74.162.79.142
Posted on Tuesday, August 25, 2009 - 12:58 pm:
With all that cargo space?
A nice, compact extension ladder that's at least three rungs
higher than the roof, is the best thing to have with you.
You can add rings on the side or rear of the bus to tie the ladder
to, for extra stability. The ladder would come in handy for fixing
upper marker lights, windshield seal leaks, etc.... all the things
that a rear mounted ladder would be totally useless for.
Walmart, Home Depot, etc sell great multi-adjustable ladders
that can also be used as scaffolding. I have one, and when I
worked on my side windows, it was absolutely fantastic!
Remember that the rungs should extend over the roof height
by at least three rungs!
ladder1
ladder2
ladder3
ladder4
Username: Joe_camper
Post Number: 182
Posted From: 98.212.104.155
Posted on Tuesday, August 25, 2009 - 3:38 pm:
I have see a Prevo-Liberty conversion with a split roof ladder up the back just as you described.
The bus was for sale on line if I can find it I will pass a photo along.
FloridaCliff (Floridacracker)
Username: Floridacracker
Post Number: 418
Posted From: 97.101.146.143
Posted on Tuesday, August 25, 2009 - 3:44 pm:
I am with JohnMC9
Get a portable ladder so you can move it where you need it.
No additional leak points added by drilling holes.
Can be used for other things like getting to windows, awnings...etc.
I am pretty agile, but I like being able to put a ladder where I need it. Walking back and forth on a 40' bus is not my idea of necessary fun.
Those collapsable ladders are really nice.
Cliff
clint hunter (Truthhunter)
Username: Truthhunter
Post Number: 419
Posted From: 24.129.232.219
Posted on Tuesday, August 25, 2009 - 4:22 pm:
my old electric trolleys had fold out step/handholds on the side, mounted to a bit of frame channel for strength. Might be on alternative, but I found them a lot more discomforting to use than a secured step ladder.
I have seen many rear engine / rear radiator stick'n'staples with a sectioned rear ladder, should be plenty of them in the scrap yard by now.
ED Hackenbruch (Shadowman)
Username: Shadowman
Post Number: 151
Posted From: 70.192.253.121
Posted on Tuesday, August 25, 2009 - 4:30 pm:
I use a Telesteps telescoping ladder that takes up very little space....and since MCI 5As only have 2 bays that is important to me.
