Joe Beleskey (Joebus)
Registered Member Username: Joebus
Post Number: 30 Registered: 1-2001 Posted From: 74.13.57.238
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 30, 2009 - 8:49 am: | |
I have a 1977 MC8, with the original "power assist" steering box. I am changing to a box from a MC9 (I believe a "Sheppard". I purchased the mounting plate kit from Sam Caylor, and it looks like it shouldn't be to hard to do...... Question: what if anything do I need to do to the power steering pump....less pressure....more pressure...do nothing? Thanks Joe |
Roger Dalke (Roger_d)
Registered Member Username: Roger_d
Post Number: 20 Registered: 8-2007 Posted From: 205.206.150.143
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 30, 2009 - 11:12 am: | |
I have a Freightliner box in my mc7, and nothing done to the pump. Works great! Roger |
clint hunter (Truthhunter)
Post Number: 438 Registered: 1-2009 Posted From: 24.129.232.232
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 30, 2009 - 3:01 pm: | |
...do change filter and flush fluid while your in there, even if just to run a gallon through to where you disconnect the old and change/clean the filter , and catch what flows out (under very dangerous pressure if you start the engine for a few seconds with the system open to power flush)... .there was a good article on this modification somewhere amongst BNO non-forum, if you look for it of the main page. Might have been fred hobbes who authored it. Don't recall anything about needed a pressure modification when he installed a sheperd integrel steering box from a "cornbinder" |
Post Number: 936 Registered: 10-2006 Posted From: 76.200.209.136
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 30, 2009 - 3:52 pm: | |
Many hydraulic systems have a filter in the low pressure return line. Might make sense as there sure cheap enough insurance. However our Sportscar is manual and the new VL is Air O Matic , so I dont know id there IS a low pressure return. FF |
Ralph Peters (Ralph7)
Post Number: 43 Registered: 3-2004 Posted From: 206.251.5.175
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 30, 2009 - 4:49 pm: | |
The filter is in the resivor, on MCI an TMC. |
David Lower (Dave_l)
Post Number: 191 Registered: 11-2007 Posted From: 67.58.201.132
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 03, 2009 - 6:20 pm: | |
Roger what year and model of freightliner did the box come from. I am interested in doing something similar in my MC7. Dave L |
