Surge tank repair'06 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » September 2009 » Surge tank repair'06 « Previous Next »
Darrell Black, DVM (Darrelldvm)
Username: Darrelldvm
Post Number: 42
Posted From: 209.78.171.84
Posted on Tuesday, September 01, 2009 - 12:10 am:
The bottom of my cooling system surge tank is beginnig to leak ever so slightly. The bottom has some cracks in it. The Questions: (1) Is tank replacement difficult? (2) Is repair of the tank bottom feasable? [It's Aluminum I think.] (3) Does anyone have one?
clint hunter (Truthhunter)
Username: Truthhunter
Post Number: 449
Posted From: 24.129.232.232
Posted on Tuesday, September 01, 2009 - 10:14 am:
you might look into the gas tank liner that is sold for motorcycle tanks, not sure how it holds up to antifreeze, or the slight pressure your system creates. Where is the leak , on a seam or corrosion from galvanic action near a mount. Depending on where & why of the leak , it may be best to get another tank.
larry currier (Larryc)
Username: Larryc
Post Number: 268
Posted From: 205.188.116.203
Posted on Tuesday, September 01, 2009 - 1:03 pm:
I have had good luck TIG welding a large aluminum patch over the entire cracked out area.
Username: Chessie4905
Post Number: 1611
Posted From: 71.58.110.9
Posted on Tuesday, September 01, 2009 - 3:07 pm:
Make sure it isn't actually a gasket leak running down over the tank. Best bet is to remove rad and separate tank from core; lots of bolts. Easier way would be to remove and take it to a radiator shop that works on truck radiators. If the tank is bad, either have it alum welded or get a good used one or NOS if you can find one. If it is cracked, try to figure out why. Those tanks were pretty sturdy.
Username: Lsilva
Post Number: 283
Posted From: 24.164.20.23
Posted on Tuesday, September 01, 2009 - 4:45 pm:
John,
I think Darrell is talking about the surge tank, not the radiator tank.
Darrell,
Depending on your tolerance for acceptable vs perfect, I would clean up the bottom as best I could and try JB Weld on it. Nothing to lose if it works, easy enough to grind off later if you need more extensive repair.
Len
Post Number: 452
Posted From: 24.129.232.219
Posted on Tuesday, September 01, 2009 - 6:08 pm:
I'm guessing (again) that the cyclops has radiators even in the surge tank, you know those nuclear powered contraptions, always giga - joules of spare energy to shed for redundancy ( think a run-a-way jimmie is messy), or so I have heard...
Username: Lsilva
Post Number: 284
Posted on Tuesday, September 01, 2009 - 6:10 pm:
You are one very strange cat! And I love you for it.
Username: Pd41044039
Post Number: 391
Posted From: 69.77.145.30
Posted on Tuesday, September 01, 2009 - 9:42 pm:
Truthunter, your diet isn't rich in wild mushrooms by chance, is it?
Post Number: 1612
Posted on Tuesday, September 01, 2009 - 10:05 pm:
If you are talking about the overflow or expansion tank, I believe they are made of brass. Remove it and solder it or have a radiator shop repair it.
Post Number: 43
Posted on Wednesday, September 02, 2009 - 12:05 am:
Seems like Larry has actually had experiece repairing the surge tank, Larry, the tank is Aluminum, correct?
Username: Larryc
Post Number: 270
Posted on Wednesday, September 02, 2009 - 2:35 pm:
Darrel,
I thought you said it was aluminum and that is how I have made long lasting repairs to aluminum cooling system parts.
Scratch it with a knife and try a magnet on it and you should be able to tell.
Post Number: 455
Posted on Wednesday, September 02, 2009 - 6:34 pm:
nope jimbob , ain't caught a buzz in many decades; the cyclopes is something special, the nuclear powered bus from "the big bus" movie , which reportably john w. roan now has custody off, just trying to encourage him to share that beast with us more-normal busnuts servants.
Post Number: 1613
Posted on Wednesday, September 02, 2009 - 10:58 pm:
If it is aluminum, you can repair it with a special alloy alum rod and a Bernzomatic torch. They sell these online and at car shows,tool shows, etc. Sometimes they show soldering soda cans together with it Clean well, heat till solder melts ans rub into crack or hole. This stuff is awsome. I repaired a hole in an AC condenser with it and it is still holding. Very strong repair.Here is a kit with the brush you need for cleaning. Hundreds of uses
http://cgi.ebay.com/ebaymotors/Alumiweld-Standard-Kit-Aluminum-Repair_W0QQcmdZViewItemQQ_t rksidZp3286Q2ec0Q2em14QQhashZitem35a31d4ec4QQitemZ230369873604QQptZMotorsQ5fAutomotiveQ5fT ools
