Darrell Black, DVM (Darrelldvm)
Registered Member Username: Darrelldvm
Post Number: 45 Registered: 6-2005 Posted From: 209.78.171.84
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 07, 2009 - 12:56 am: | |
I want to direct my exhaust to the side rather than straight back. Where do I find a tail pipe that will fit 3.5 " exhaust "collector"? What length works? Do you use round tip or flaghtened? |
peter river (Brightstone)
Registered Member Username: Brightstone
Post Number: 1 Registered: 8-2009 Posted From: 24.234.166.174
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 07, 2009 - 3:33 am: | |
I had a damaged tailpipe on my bus. the tailpipe is mounted to the muffler using a clamping mechanism that's easily loosened. I called up the local muffler shop and asked if they had a length of scrap 4" exhaust pipes. price varied from $10 to $40, so I went over to the $10 place and it was a cheap direct replacement. if your exhaust is 3.5", you can easily find a tail pipe tip at any auto store, of different design to fit on it. (Message edited by brightstone on September 07, 2009) |
Brandon Merritt (Brando4905)
Registered Member Username: Brando4905
Post Number: 19 Registered: 3-2009 Posted From: 24.5.54.180
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 07, 2009 - 1:36 pm: | |
Just had this issue. 3.5" is hard to find without ordering a section online. I found the length of 4" that I needed, and had muffler shop weld it to the existing 3.5". |
