?? for fast fred Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » December 2002 » ?? for fast fred « Previous Next »
MCI-1 (24.191.163.130)
Posted on Thursday, December 12, 2002 - 8:17 pm:
You were right ,My non working bay door lights are draining my battery. What should I do??
eddie acker (Citykid) (64.12.96.235)
Posted on Thursday, December 12, 2002 - 10:15 pm:
Take the lights out. Cut the wires then tape them off till you get new lights.You could find some on ebay.
FAST FRED (209.26.115.217)
Posted on Friday, December 13, 2002 - 5:35 am:
Many old coaches need some love , both in looking for electric losses , or tiny air leaks.
Glad you found the first few , but if you look on the wiring schematic , you may find other items , no longer used , but not properly terminated.
Same for air stuff , on Gm's the air went to the gradustat & was used in the air cond clutch / safty system.
Another place to check that if its removed , its OFF correctly.
Buswarrior (Buswarrior) (64.229.212.157)
Posted on Friday, December 13, 2002 - 2:00 pm:
I would pay particular attention to the switches that are supposed to turn the lights on.
Notorious for rusting on our vintage coaches, and since they work by grounding, just a little high resistance rust in there and you have an electron leak!
Who knows, you might get them working again quite easily with a little switch attention or replacement. Pretty simple momentary-on push buttons.
