FRP Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » September 2009 » FRP « Previous Next »
Frank Radosti (Frank4104)
Username: Frank4104
Post Number: 35
Posted From: 64.80.137.250
Posted on Monday, September 28, 2009 - 8:41 am:
my bus has frp on the cileing can i paint it want to restore its bright white color whats the prep and procdure...Thanks Frank.
clint hunter (Truthhunter)
Username: Truthhunter
Post Number: 526
Posted From: 24.129.237.52
Posted on Monday, September 28, 2009 - 10:27 am:
clean it really well with simple green and a pot scrubber pad then first, melamine paint should work well, I haven't tried this yet in this application. It works excellent for counter tops made of arborite. A light sanding makes for better adhesion , but likely not needed on a ceiling, just get it clean & rinsed clean.
Username: John_mc9
Post Number: 988
Posted From: 74.162.65.133
Posted on Monday, September 28, 2009 - 11:33 am:
FRP is just fiber reinforced plastic, so I wouldn't use anything that's
not designed to be used on plastic surfaces.
Try whatever you finally settle on, in a closet, or hidden spot in
a cabinet, or bath first.... just to be safe. You wouldn't want an
ugly stain where it's noticeable, ehh?
Post Number: 528
Posted From: 24.129.232.219
Posted on Monday, September 28, 2009 - 3:52 pm:
ah so then is seems it is the same stuff in the MC 8 used on the ceiling, thanks McJay9. Then I would guess a few coats of melamine is a good bet, just don't do the test spot above the bed , in case it doesn't work out, the stain will get to you there. Most melamine's recommend a aklyd primer on a light sanding, and a final wipe with acetone on rags. mini rollers will spread the coat better than paintbrushes.
-I would suggest the super duper alkyd primers as they are more sticky. If your going to coat a dark color with white, you will be doing several coats , prep is the key to a lasting job.
Post Number: 967
Posted From: 76.202.165.190
Posted on Tuesday, September 29, 2009 - 7:06 am:
Bartenders Friend and a sponge
FF
Username: Frank4104
Post Number: 36
Posted on Tuesday, September 29, 2009 - 8:12 am:
Thanks to all!!
