thomas flocks (Taflocks)
Registered Member Username: Taflocks
Post Number: 24 Registered: 9-2009 Posted From: 69.205.11.117
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 18, 2009 - 11:06 pm: | |
i need to drain all the water out of my system but dont see a drain from the hot water heater, any ideas? i did find a main drain before and after the water pump and left them wide open to drain but cant be sure the hot tank also drained. |
Tim (Timkar)
Registered Member Username: Timkar
Post Number: 131 Registered: 10-2004 Posted From: 64.141.73.7
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 19, 2009 - 12:53 am: | |
What model is the water heater? I take it you are referring to a domestic HWH. If so there is normally a drain, a plug or an anode near the bottom of the unit which can be removed for draining. HTH...Tim |
Post Number: 25 Registered: 9-2009 Posted From: 69.205.11.117
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 19, 2009 - 6:48 am: | |
0i will look again, i was expecting a pitcock at least. |
Dan West (Utahclaimjumper)
Post Number: 206 Registered: 1-2005 Posted From: 208.66.38.60
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 19, 2009 - 7:48 am: | |
More than Likely its an RV heater, it will have a plastic plug at the bottom or an anode rod that will look like a metal plug from the outside.>>>Dan |
Post Number: 990 Registered: 10-2006 Posted From: 75.60.109.64
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 20, 2009 - 6:38 am: | |
Many folks will install a heater bypass kit ($15 or so) that allows the HW heater contents to be drained , as the FW system is filled with RV antifreez. In really cold weather this is safer than simply blowing the FW system out. Be sure to get pink into the sink sprayer or it will freeze . The sink traps will also need a splash . Da DD Book has all the info on , "out of service for over 30 days". FF |
Jim Rink (Fakeguy)
Registered Member Username: Fakeguy
Post Number: 155 Registered: 1-2005 Posted From: 96.11.208.166
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, October 22, 2009 - 11:19 pm: | |
What do you guys put in your diesel fuel for winter storage? Thanks in advance |
