Air Con Power Draw Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » October 2009 » Air Con Power Draw « Previous Next »
Username: Oonrahnjay
Post Number: 475
Posted From: 70.60.107.113
Posted on Monday, October 26, 2009 - 11:33 pm:
Hi, Folks. I'm sorry about all my basic questions but I'm right in the middle of my spec work.
I'm looking at an air con unit that's spec'd at 1150 watts (normal running power draw) with a rating on 5750 (or about 6 times as much) at start up and "stalled compressor".
Is this typical? Thanks, BH NC
Rob Norgren (Robsedona)
Username: Robsedona
Post Number: 162
Posted From: 75.210.211.233
Posted on Thursday, October 29, 2009 - 9:57 am:
I know for 2 to start you need a 8kw gen and for 3 12KW gen So I would think from this they are under 5750 for 5750 to start 3 with nothing running you would need a 18KW gen and a 12KW gen to start 2 and be running nothing elce. On mine I can run 2 airs and the Microwave at the same time on 8KW gen(that is all on start up and runs fine)
I thing is about 2 times the power on start up!
I hope this helps I do not see the start up info in my old Info on the AC
Username: Pete_rtsdaytona
Post Number: 582
Posted From: 97.104.18.110
Posted on Thursday, October 29, 2009 - 11:09 am:
Rull of thumb - use to be ????
4KW for 1 rooftop ac
6kw for 2 rooftop ac's
the run watts are approx 1.5 kw for avg rooftops
But I guess with Electric H/W heaters and M/W's that may have change ??
Username: Robsedona
Post Number: 163
Posted on Thursday, October 29, 2009 - 11:53 am:
OK as I understand it 1150watts takes 1150 watts to run and more to start up and when it cycles from AC to just fan. Now you have to look at all running things and also your phantom draw ac also has a running draw and a start draw that are different Microwave also has a start draw and a run draw. If all things Cycle at the same time and it = more then you have Blown fuse Gen may stop making AC power and need to be stopped and restarted! most all elec devices give you this Info in their spec.
One way is to go computer control or CAN or RV-C then you have the Cycle and start control on a system that keeps things from cycling together and you get away with less KW Gen or less AC from your cord to run the same equipment
Username: Chessie4905
Post Number: 1724
Posted From: 71.58.71.157
Posted on Thursday, October 29, 2009 - 9:34 pm:
Fred once mentioned a capacitor package to help start AC with marginal capacity generators. Also, be sure to check the actual wattage output of any generator, as they usually rate them by surge output.
Username: Robsedona
Post Number: 167
Posted From: 75.208.25.87
Posted on Saturday, October 31, 2009 - 10:59 am:
capacitor package remember to put warnings around this People can get a big shock from a full Capacitor if they become the discharge path!
