Coach Burned Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » November 2009 » Coach Burned « Previous Next »
NH BIll (Nh_wanderer)
Username: Nh_wanderer
Post Number: 30
Posted From: 98.229.237.8
Posted on Sunday, November 08, 2009 - 7:46 am:
Hello all,
Some friend's 1995 Blue Bird Wanderlodge coach burned a few nights ago while it was plugged in at their home. They had just returned from five weeks on the road.
They were in the house eating when he smelled the electrical burn and alarms in the coach went off. The fire appears to have started in the front at the genset.
He put hoses and extinguishers on it at once, called 911 and the fire dept came put it out. Then the fire department left.
At this point the damage was confined to the front and primarily in the generator compartment.
He towed the coach away from the house and left it in the driveway. They went out to get a pizza and less than an hour later got a call from a neighbor stating they heard an explosion and the entire coach was in flames!
Still trying to determine the exact cause. Speculating it might have been a chaffed battery cable grounding out.
The following link is to a current "lessons learned" discussion and more photos.
Randy and Carol have owned buses for over 30 years and are very knowledgeable about them.
The point is, this could happen to any of us.
Condolences to Randy and Carol.
< http://www.wanderlodgeownersgroup.com/forums/showthread.php?t=4558 >
NH Bill
(Message edited by NH_Wanderer on November 08, 2009)
Post Number: 654
Posted From: 71.53.155.14
Posted on Sunday, November 08, 2009 - 7:53 am:
Gosh!! Condolences to them also. Thanks Bill
Gomer
thomas flocks (Taflocks)
Username: Taflocks
Post Number: 66
Posted From: 69.205.11.117
Posted on Sunday, November 08, 2009 - 10:19 am:
that sucks...i just found 3 loose battery connections and one on the genset i will look for chafing this morning.maybe battery shutoffs would be a good idea for storage use?
Username: Vivianellie
Post Number: 385
Posted From: 75.178.92.43
Posted on Sunday, November 08, 2009 - 1:01 pm:
My condolences too. That is just awful...if I put myself in their place I'd be totally devastated.
I pray things work out for them.
Nellie Wilson
Post Number: 1737
Posted From: 76.68.122.187
Posted on Sunday, November 08, 2009 - 1:07 pm:
Interesting... the first thing the fire department likes to do is cut the battery cables with the bolt cutters...
Sounds like they didn't in this case.
Burned wires up front, with the batteries still connected?
Recipe for disaster.
No system on that coach could be trusted after the first fire.
If you have a fire, all sources of power and fuel should be isolated until systems can be verified, and all cabling, chassis, house, shore, inverter, converter, charger and generator in the vicinity can be inspected for damage.
Your batteries and wiring need to be considered an equal or bigger danger than the propane tank.
a most unfortunate incident!
doug yes (Dougg)
Username: Dougg
Post Number: 109
Posted From: 174.131.47.77
Posted on Sunday, November 08, 2009 - 10:05 pm:
I'm glad they were not in the bus.
Post Number: 32
Posted on Tuesday, November 10, 2009 - 6:21 am:
Here is another Photo of Blue Bird Bar B Que.
Check that wiring and those fire extinguishers!
NH BIll
Josh McElhiney (Zcommanager)
Username: Zcommanager
Post Number: 94
Posted From: 75.187.41.177
Posted on Tuesday, November 10, 2009 - 11:52 am:
WOW!!! With that kind of heat and "flameage" I'm truly surprised there is anything left of the Old Bird. From the initail photo, it did not look so bad. I am surely glad nobody was inside when it became engulfed.
Best Wishes to the Owners!!
Josh
