Switch Housings Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » November 2009 » Switch Housings « Previous Next »
thomas flocks (Taflocks)
Username: Taflocks
Post Number: 67
Posted From: 69.205.11.117
Posted on Tuesday, November 10, 2009 - 10:00 pm:
i have the original switches on my 4106 and would like a new housing and new switches,is there anyone that makes a new switch panel for the 4106? maybe a lighted rocker panel type? with a key switch. also what is the emerg stop button for?i was started today and decided to try it out and nothing happend???
Username: Chessie4905
Post Number: 1748
Posted From: 71.58.71.157
Posted on Tuesday, November 10, 2009 - 10:07 pm:
The emergency stop button is to shut off the engine in an emergency, like a runaway engine. It releases a flap in the intake air passage pipe that goes between air cleaner and blower. The flap shuts off about 95 percent of the air going into engine, causing it to stop or drop down to idle with a great deal of black smoke. It is manually reset to it's open condition (while engine is off) and after problem is corrected. It sounds like it may not be working; this should be repaired at your earliest convenience. I think R and M fiberglass makes custom dash panels for many coaches. You can check their site.
Username: Bigrigger
Post Number: 290
Posted From: 24.183.21.246
Posted on Tuesday, November 10, 2009 - 10:09 pm:
Emergency stop on a Detroit is a fail safe for a runaway engine. It is supposed to drop a flap across the air intake making the engine inoperable. That flap then needs to be reset by hand before the engine can be started again. I sure someone will have a much more involved explanation, but thats my basic understanding.
LOL you beat me by a minute John!
(Message edited by bigrigger on November 10, 2009)
Username: Taflocks
Post Number: 68
Posted on Tuesday, November 10, 2009 - 10:16 pm:
it may have a broken wire or was removed by the p/o?
Ken Barnett (Dieselbusparts)
Username: Dieselbusparts
Post Number: 6
Posted From: 76.26.111.30
Posted on Tuesday, November 10, 2009 - 11:22 pm:
This is the panel that Mr. Roan had suggested:
http://www.rm-fiberglass.com/bus/parts/102-45.html
Username: Taflocks
Post Number: 69
Posted on Wednesday, November 11, 2009 - 12:13 am:
dosent really float my boat.... i was looking for the panel on the left with the starter lights and fan switches.
Post Number: 996
Posted From: 69.19.14.44
Posted on Wednesday, November 11, 2009 - 6:05 am:
The switches on a Sportscar may be subject to water from a window leak or open toll hole.
MY way was to replace the std. switches with marine grade Cole Hersey switches.
Better Sealed and silver contacts.
Check Defender industries in Ct for fair prices.
Not expensive and easy (R&R) to do.
FF
Rob Norgren (Robsedona)
Username: Robsedona
Post Number: 172
Posted From: 75.211.63.16
Posted on Wednesday, November 11, 2009 - 11:19 am:
DD in an article said to disable the stop switch and something about a fuel shut off switch.
When the flapper closes it can blow the seals and suck oil from the engine and run on the oil until BAMB! If you have a Skinner valve in the fuel line you can use the emergency stop to shut off fuel to the engine! Just what I've been told By DD people who knew way more then ME
Rob
Wec4104 (Wec4104)
Username: Wec4104
Post Number: 72
Posted From: 71.59.85.113
Posted on Wednesday, November 11, 2009 - 1:35 pm:
Yes, it was common for bus operators to disconnect the emergency stop switch. I can think of two reasons why it probably caused a lot of grief and aggravation. First, if the switch is ever triggered while parked, there is no clue to tell the next driver that the flap was left in the activated position. A newbie could waste a lot of time headscratching. Second, the toggle switch looks just like all the other toggle switches and it would be way to easy to flip it when reaching for another switch.
I have personally experienced the joy of a run away DD while driving down the PA Turnpike (stuck injector). At the time, my emergency shutdown switch was disconnected, and I was wishing it was not. I have since reconnected it and have installed a switch cover/guard over it that you can buy at autoparts stores. Activating the switch is not a two step process whereby I flip open the cover and then can throw the toggle switch. I painted the cover to match the dash.
I don't disagree that the skinner valve to cut off the fuel feed is a better solution. But I at least like the option of having the emergency switch available if needed.
(Message edited by wec4104 on November 11, 2009)
Username: Gusc
Post Number: 1038
Posted From: 209.142.172.136
Posted on Wednesday, November 11, 2009 - 7:26 pm:
I, too, have covered my emergency stop switch with a guard so that it has to be a determined effort to use it.
I really don't worry about blown blower seals if I have a real emergency.
Compared to a real runaway DD seals are a minor annoyance!!
Post Number: 1740
Posted From: 76.69.140.208
Posted on Wednesday, November 11, 2009 - 9:47 pm:
Every coach I have ever driven that had an emergency stop switch, the switch had a cover on it.
someone taking souvenirs off yours before you got it?
Bill Holstein (Billmoocow)
Username: Billmoocow
Post Number: 39
Posted From: 98.232.207.25
Posted on Wednesday, November 11, 2009 - 10:52 pm:
When i first got my bus the flap was wired open as they did not want it to ever be used?! I have since taken the wire off so that it can be used. Unfortunately it still does not work. Need to run some more tests to see why it does not engage.
Wec4104 (Wec4104)
Username: Wec4104
Post Number: 73
Posted on Thursday, November 12, 2009 - 7:36 am:
Buswarrior: I can't speak for the other coaches you have driven, but I don't think 4104s originally came with covers over the emergency stop switch. The manuals I have include photos of the dash, and in none of these is there a switch cover. Given the similarity of the 4106 dash, I'd say there is a very good chance these came without the cover also.
Post Number: 664
Posted From: 71.53.155.14
Posted on Thursday, November 12, 2009 - 8:30 am:
Wec; My 1957 4104 Gm has the emergency stop switch on the dash with the cover over it also. I have made sure it works and since looking at this thread, I am putting a fuel shut-down solonoid on it as well so when you hit the emergency switch it activates Both.
Gomer
Username: Pd41044039
Post Number: 414
Posted From: 184.0.7.177
Posted on Thursday, November 12, 2009 - 11:48 am:
When we got our 4104, the flap was wired open and the switch had a red guard you have to flip out of the way. Turns out it was wired because the notch on the cam was worn & it would jiggle & apply itself going down the road! I disassembled the flap & cam (it was real stiff from being wired open) and repaired the worn part (I reground the worn edge to be a sharper corner to match the unworn section) I haven't had a bit of trouble since. The fuel solenoid is good, but if your engine ever runs away, it will run way longer than you want to be there waiting for it to run out of fuel (it could take 5 minutes) while it screams at maybe 3000 rpms. And if it starts to run on it's own oil, the fuel solenoid won't stop it. Later mechanical engines have spring loaded rack arms so if one injector stuck, the rack can still close. That's why they stopped using the flap.
Username: Bigrigger
Post Number: 292
Posted on Thursday, November 12, 2009 - 12:15 pm:
They also told me with my GMC that had oil bath air cleaners that in the event of a roll over the oil in the air cleaner would be sucked in and cause a runaway engine. I guess if my semi was laying on its top, the engine racing would not be my main concern!
Username: George_mc6
Post Number: 924
Posted From: 99.39.13.151
Posted on Thursday, November 12, 2009 - 3:47 pm:
I really agree with Jim! The engine can indeed run away because of a stuck injector, but also from being in a combustible atmosphere. (A gasoline or natural or propane gas leak.) The Dodge owners manual states that to stop a runaway engine, shoot a CO2 type fire extinguisher under the right fender where the air intake is. Under these circumstances, a fuel shut off solenoid won't do any good, and we have to remember that any time the engine is turning faster than the throttle is asking, that the governor will have the rack in the no-fuel position if the rack isn't stuck.
G
