Automatic for Eagle Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » November 2009 » Automatic for Eagle « Previous Next »
Wayne Ellenburg (Wlnburg)
Username: Wlnburg
Post Number: 75
Posted From: 173.24.219.217
Posted on Thursday, November 12, 2009 - 5:15 pm:
I have found some HT740 transmissions how do I know if they will work in an Eagle?
Transmission tag
Username: Luvrbus
Post Number: 792
Posted From: 74.33.54.207
Posted on Thursday, November 12, 2009 - 6:29 pm:
Wayne, that will work for you the numbers say it is for a Detroit Diesel , 2100 rpm and 7 inch oil pan.
So that has the shift points and torque converter for a DD up to 450 hp
Depending on the bus some 05 Eagles you need to modify the engine compartment on the drivers side not a major deal but just enough to clear takes about a hour.
If you can locate a used Stone/Bennett shifter it would make life easy for you installng
good luck
(Message edited by luvrbus on November 12, 2009)
Larry Baird (Airhog)
Username: Airhog
Post Number: 174
Posted From: 75.209.189.226
Posted on Friday, November 13, 2009 - 12:59 am:
I have a just rebuilt 740 with retarders I want to sell in So Cal if your interested and it setup for a DD
