Post Number: 1006 Registered: 10-2006 Posted From: 66.82.162.10
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 20, 2009 - 6:49 am: | |
My Sportscar has a later model tranny than the origional, I guess a "million " miles for Carry Coach in NYC airport traffic took its toll. The replacement has the usual low pressure sender, but it has a second sensor , two slip on terminals . Neutral ? Speedometer? DA Book shows a dip stick with a hot/cold set of markings, the one I have has a single marking. Could someone with a marked stick let me know the measurements from the top, so I can remark my stick? TIA folks, FF |
Post Number: 684 Registered: 3-2007 Posted From: 71.53.153.91
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 20, 2009 - 4:54 pm: | |
FF I am assuming that you have an automatic. Is that right? Gomer |
Larry Nelson (Larryn4106)
Registered Member Username: Larryn4106
Post Number: 41 Registered: 8-2008 Posted From: 173.30.230.77
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 20, 2009 - 7:50 pm: | |
If FF has an automatic....dogs will start dating cats, and so on.... |
Post Number: 685 Registered: 3-2007 Posted From: 71.53.153.91
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 20, 2009 - 8:42 pm: | |
he he gomer |
Dan West (Utahclaimjumper)
Post Number: 211 Registered: 1-2005 Posted From: 208.66.38.60
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 20, 2009 - 10:32 pm: | |
You have to use "SLUSHBOX" or he wont know what your talking about.>>>Dan |
Post Number: 1762 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, November 21, 2009 - 9:43 am: | |
My 4905 dip stick only has a full line. My 4104 has full cold and full hot marks. Full hot is one inch above full cold. The 4905 tranny has a low oil pressure sensor, neutral or starter safety switch, and a back-up light switch. The B/U switch is an option. Mounts in passageway at end of reverse shift rod. |
Post Number: 1007 Registered: 10-2006 Posted From: 66.82.9.74
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, November 21, 2009 - 4:44 pm: | |
Probably is the neutral safety switch. Thanks! No,, this sportscar has the good old std 4 speed that requires double clutching , up and down. Otherwise how would I stay over 9mpg ? The "new" '56 Vl 100 will have a Kraut ZF HP 600 5 speed with .84 OD . However when not towing we are hoping for 13mpg+ and even 15? in the flatlands. Time will tell, although our luck in finding a suitable rear end with 2.6 to 2.9 ratio will be the key. With a 2.6 , with disc brakes (lighter), and low resistance tires , there IS a chance , of course a Ser: 50 with 40 lbs of turbo and electric injection is also key factor.. Stay tuned! FF |
Don Evans (Doninwa)
Post Number: 240 Registered: 1-2007 Posted From: 208.81.157.234
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, November 21, 2009 - 8:52 pm: | |
FF, if you think the Spicer in our 66 4107 would be the same, or shed any light on your dip stick I will measure it. It's all of a mile and a half round trip. If the forecast stands up I might have to shovel snow to get the tranny door open! Let me know. Don 4107 |
Post Number: 1008 Registered: 10-2006 Posted From: 69.19.14.28
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 22, 2009 - 4:38 pm: | |
Don Its OK , I would like the measurement , but its been this way a couple of years, so measure it at your leisure , after the Spring Thaw starts! FF |
