Post Number: 105 Registered: 10-2004 Posted From: 24.218.65.24
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 24, 2009 - 6:53 pm: | |
Hey All, Anyone remember the guy who built his own holding tanks out of plastic? I'm going to do the same thing.I need to know what the meterial was and where he go the plastic welding stuff. |
Post Number: 1767 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 24, 2009 - 7:45 pm: | |
this site may help. Also check archives. And do a search on plastic welding. Lot of info out there. http://www.wegenerwelding.com/videos.htm |
Post Number: 688 Registered: 3-2007 Posted From: 71.53.153.91
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 24, 2009 - 7:52 pm: | |
Hey at the top of the page is a link: Plastic Mart.com/storage tanks |
Post Number: 302 Registered: 9-2007 Posted From: 24.183.21.246
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 24, 2009 - 8:33 pm: | |
Hi Doug, I looked back through my old issues of "Bus Conversions" and Sept 2001 George Myers had a great article entitle "Tanks". Talks all about the various buy and build your own variety, how to calculate size and need, etc. In the materials section he talks about ABS plastic sheeting 1/4 inch thick. They are glued together using standard ABS plumbing cement and then built into a tight fitting plywood box. Lots of other good info in the article also. If you want I can try and scan it and send it or maybe the Bus Conversion archives will have it. Let me know although I will be "on the road" until Thanksgiving day. Good luck, John |
Ednj (Ednj)
Post Number: 266 Registered: 3-2003 Posted From: 173.3.46.87
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 24, 2009 - 9:25 pm: | |
http://www.gumpydog.com/bus/MC9_WIP/Plumbing/Holding_Tank_Fabrication/holding_tank_fabrica tion.htm |
Jim Wallin (Powderseeker01)
Registered Member Username: Powderseeker01
Post Number: 47 Registered: 10-2008 Posted From: 208.68.48.77
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 25, 2009 - 8:34 am: | |
Take a look at tank depot(tankdepot.com)Good selection, fittings where you want them, and reasonable prices. |
thomas flocks (Taflocks)
Registered Member Username: Taflocks
Post Number: 84 Registered: 9-2009 Posted From: 24.226.54.174
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 25, 2009 - 8:54 am: | |
and what happens if you do a bad job and the walls burst on your poop box? |
don goldsmith (Bottomacher)
Registered Member Username: Bottomacher
Post Number: 266 Registered: 12-2000 Posted From: 72.152.137.154
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 25, 2009 - 9:26 am: | |
Your bus gets all poopy. |
Post Number: 85 Registered: 9-2009 Posted From: 24.226.54.174
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 25, 2009 - 9:45 am: | |
that would be the sh**s |
Post Number: 458 Registered: 10-2003 Posted From: 66.165.176.62
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 25, 2009 - 11:05 am: | |
I just don't see the advantage to building I bought mine from http://www.rvsurplus.net/catalog/display.php?category_id=47 Paid less than $200 for an 85 gallon Fresh water tank with outlets where I needed them shipped to my office |
Tom Christman (Tchristman)
Post Number: 147 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 25, 2009 - 12:29 pm: | |
Personally-I would suggest just buying pre-made tanks. Here in Los Angeles, I have bought from El Monte Plastics and they make fresh water tanks up to 275gal. Then they will also install the pipe fittings where you want. I used them with my 18 wheeler, and in 800,000 miles of truck driving (10 times the vibration of a bus) no failures. Good Luck, TomC |
Post Number: 324 Registered: 12-2000 Posted From: 72.187.35.208
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 25, 2009 - 12:30 pm: | |
The advantage to building is that you can make the tanks the exact size you need to maximize both tank capacity and bay space. |
Post Number: 459 Registered: 10-2003 Posted From: 66.165.176.62
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 25, 2009 - 1:25 pm: | |
Len ifyou check out that site I posted there is an almost infinite variety of sizes shapes and configs but too each his own |
Post Number: 106 Registered: 10-2004 Posted From: 24.218.65.24
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 25, 2009 - 4:31 pm: | |
Thanks All The reason I need to custom make mine is because I have to put the gray and black water tank( combined) just in back of the front axel and I have to go around my radiator and also incorperate the propane tanks in that space so I really need to custom build them. Ya, Gumpydog was the guy I was looking for. Thanks again. You guys are the best! |
Jim and Myrna Lawrence (Daffycanuck)
Registered Member Username: Daffycanuck
Post Number: 58 Registered: 10-2004 Posted From: 69.19.14.15
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, November 28, 2009 - 11:14 pm: | |
WHAT EVER YOU DO, do NOT use plumbers ABS cement to glue the ABS sheets. I built mine using 1/4" ABS plastic. A trial glueing proved that the plumbing cement isn't strong enough. I made my own glue with shaved ABS, Toluene and Acetone. I cut triangular pieces for all the corners and glued and screwed (small stainless). Also baffles. None of the 4 tanks I built have plywood boxes around them. I have had trouble with one large water tank after I blew it up with high pressure filling. Make SURE you have a vent larger than the input...mine wasn't hence the blowup!! The tanks have been in constant use now for 12 years, but if I had to do it all over again, I would have a plastics company make them for me. I built my own to fit in specific spots, but I'm sure there are companies out there who could do the same. |
Ray Drummond (Ray_d)
Registered Member Username: Ray_d
Post Number: 63 Registered: 4-2006 Posted From: 68.126.134.114
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, November 28, 2009 - 11:29 pm: | |
ABS can also be heat welded. Ray D |
