Jerry Coombs (Jerry_c)
Registered Member Username: Jerry_c
Post Number: 23 Registered: 11-2005 Posted From: 71.52.110.125
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 25, 2009 - 3:49 pm: | |
Already did a topic search and nothing came up -- does anyone have some recomendations for engine instrumentation sources -- engine temp, oil pressure, etc. Thanks - - |
Post Number: 689 Registered: 3-2007 Posted From: 71.53.153.91
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 25, 2009 - 4:20 pm: | |
check with Pete as he has listings on the parts for sale here on Bus Nuts gomer |
Post Number: 325 Registered: 12-2000 Posted From: 72.187.35.208
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 25, 2009 - 4:21 pm: | |
http://www.egauges.com/ Personally, I like the VDO Vision line. (Message edited by lsilva on November 25, 2009) |
Post Number: 584 Registered: 1-2005 Posted From: 97.104.18.110
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 25, 2009 - 6:10 pm: | |
Sorry my ads expired - so here's the data $199 + $15 shipping -> Nine Gauges (Surplus Monaco Diesel M/H) 2 1/8" and 4 5/8" Speedo--->0-85 MPH w/Odometer & trip (switch settable(10,000 to 112,400 PULSE/MILE) Tack ----->0-4k RPM Volts----->0-18 VDC Fuel------>E-F by 1/4s Tran------>140-320F Water----->100-250 F Oil-------->0-120 PSI Air-------->0-150 PSI DUAL (mechanical/pneumatic) Boost----->0-30 PSI (mechanical/pneumatic) The following senders are (NOT PROVIDED) but are available at www.egauges.com <>Water temp sender - $ 6.84 - http://www.egauges.com/vdo_indS.asp?Sender=250F_120C_VDO&PN=323-095 <>Trans Temp sender - $ 6.14 - http://www.egauges.com/vdo_indS.asp?Sender=300F_150C_VDO&PN=323-057 <>Oil Pressure sender - $25.75 - http://www.egauges.com/vdo_indS.asp?Sender=150PSI_10Bar&PN=360-025 Fuel Sender info - Standard GM 0-90 ohms 0=enpty Tach info - The tach input is preset to 12 pulses/rev p/rev - calibration procedure provided to run off Detroit Diesel 50DN Alternator "R" terminal PLEASE NOTE - I ONLY HAVE BLACK FACES AVAILABLE - The white face gauge picture is just for mounting suggestion reference (My RTS Bus Conversion) Home# 386 672-zero five seven one (Message edited by pete_rts/daytona on November 25, 2009) (Message edited by pete_rts/daytona on November 25, 2009) (Message edited by pete_rts/daytona on November 25, 2009) (Message edited by pete_rts/daytona on November 25, 2009) |
Bob Baldwin (Bob4106)
Registered Member Username: Bob4106
Post Number: 193 Registered: 10-2004 Posted From: 24.74.180.20
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 26, 2009 - 9:35 am: | |
I got one of those from Pete. Great deal and Pete was there when help was needed to understand how to do the speedo. |
Tom Christman (Tchristman)
Post Number: 149 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 26, 2009 - 11:32 pm: | |
My transit has Isspro-go to their site-they have all that's needed. I bought my tachometer and generator that is powered by the blower from them. Good Luck, Tomc |
