Austin Scott Davis (Zimtok)
Post Number: 390 Registered: 9-2006 Posted From: 209.156.24.114
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 01, 2009 - 10:14 am: | |
Below is a link to a photo album showing the front brake can replacement on my 4104. http://www.cig.usa.canon.com/p?p=DRRCptZZJTY It was quite easy to do this replacement. From the time I raised the bus to the time I set it back down was only about 2 hours. |
Post Number: 996 Registered: 7-2006 Posted From: 70.210.214.60
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 01, 2009 - 10:38 am: | |
Nice job on the photos, Austin...thanx for the "tutorial"! RCB |
Post Number: 698 Registered: 3-2007 Posted From: 71.53.153.91
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 01, 2009 - 6:56 pm: | |
Good job Austin; now I know who to call when I need one changed LOL Gomer |
Post Number: 391 Registered: 9-2006 Posted From: 209.156.24.114
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, December 02, 2009 - 9:17 am: | |
Gomer, Bring it by my place and we'll see what we can do..... ;D . |
David Hancock (Daveh)
Registered Member Username: Daveh
Post Number: 9 Registered: 1-2005 Posted From: 67.142.130.15
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, December 03, 2009 - 9:28 am: | |
Nice Job Austin!Whats the part# and where id you get them? Thanks in advance Dave H |
Post Number: 329 Registered: 12-2000 Posted From: 72.187.35.208
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, December 03, 2009 - 10:45 am: | |
Nice job and great pictures. Seems that it would have been the perfect opportunity to add spring brakes. Was there a reason you chose not to do that? Len |
Post Number: 1654 Registered: 12-2000 Posted From: 67.182.48.162
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, December 03, 2009 - 12:48 pm: | |
Len - No room for spring brakes on a 4104 or 4106 unless you cut off and reposition/weld the mounting brackets, or cut a hole in the rear baggage bin wall. FWIW & HTH. . . |
Post Number: 330 Registered: 12-2000 Posted From: 72.187.35.208
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, December 03, 2009 - 1:20 pm: | |
RJ, My understanding, though I never measured it, is that you can install standard 30-30 spring brakes on a 4104, but not on a 4106. It always looked to me that there was enough room but I did not do it before selling my bus. It looks like there is plenty of room in Austin's pictures. |
Tom Connolly (Tomconnolly)
Registered Member Username: Tomconnolly
Post Number: 54 Registered: 9-2003 Posted From: 96.252.201.44
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, December 03, 2009 - 11:34 pm: | |
I have a 4104 and I put 30-30 spring cans on the rears in 1987 and just replaced them as preventative maintenance this year. They bolt right on! (Message edited by tomconnolly on December 03, 2009) |
Patrick levenson (Zubzub)
Post Number: 132 Registered: 5-2007 Posted From: 70.52.28.2
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, December 04, 2009 - 5:22 am: | |
to wit 4104 with spring brskes.[IMG]http://i392.photobucket.com/albums/pp3/zubzub_photos/IMG_1941.jpg[/IMG] [IMG]http://i392.photobucket.com/albums/pp3/zubzub_photos/IMG_1947-1.jpg[/IMG] 2nd pic shows 30/30 can's clearance from the bulkhead. |
Post Number: 392 Registered: 9-2006 Posted From: 209.156.24.114
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, December 04, 2009 - 8:29 am: | |
David, The part is really common. I went to my local "Truck Pro" and purchased them. www.truckpro.com All you have to ask for is a "Type 24 Single Brake Chamber". I paid $30.08 per. Len, These are the front Brake chambers. I already have spring brake chambers on the rear. |
Post Number: 331 Registered: 12-2000 Posted From: 72.187.35.208
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, December 04, 2009 - 10:06 am: | |
Well, now I have thoroughly embarrassed myself by not looking close enough. Len |
Post Number: 393 Registered: 9-2006 Posted From: 209.156.24.114
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, December 04, 2009 - 11:51 am: | |
Len, It's all good.... Truth be told, there have been many times I didn't know which end I was looking at.... . |
Post Number: 490 Registered: 8-2004 Posted From: 70.60.107.113
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, December 04, 2009 - 2:29 pm: | |
This is very useful. I'm doing a conversion/rebuild on my bus's brakes. My bus was built with plain cans on all 4 corners and a big lever next to the driver with a 1/2" steel rod back to a mechanical parking/emergency brake on the rear wheels (the lever on the "S-cams" on the rear has two arms on it -- one for the cans to push on and one for the mechanical emergency brake to pull on). The cans, tanks, lines, etc. on my bus were rusty and damaged (I don't know how the tanks didn't blow out). So, I'm going to have a NAmer-built air drier, then everything between there and the wheels is going to be new NAmer-made. New cans (double in the back), new tanks, new lines, new brake light switches, new valves, new push-pull parking/emerg brake valve at the driver. I removed 131 pounds of lever, pivots, rods, etc. by taking the mechanical emerg brake system off -- I was amazed but it was some big, heavy ironmongery! Thanks for your photos and descriptions. |
