Another ? about my 4107 heater motor Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » December 2009 » Another ? about my 4107 heater motor « Previous Next »
Username: Bigrigger
Post Number: 307
Posted From: 24.183.21.246
Posted on Wednesday, December 02, 2009 - 9:28 am:
Well, I am going back over today to do some electrical testing (Not my strong suite). I have accessed the underfloor motors and both appear to be in good condition. Today I will start doing some circuit tests to see if I have power to them. The question I have is in my service manual at one point it alludes to the bus motor running before starting the heater/airconditioner motors. Is there some switch in the heater fans system that requires this, or was it just that in the case of the air conditioner (disabled now) that the pump needed to be turning before the fans were tested? The bus is inside a building and running it inside is not really a viable option.
Thanks in advance for any input,
John T
Bill Gerrie (Bill_gerrie)
Username: Bill_gerrie
Post Number: 315
Posted From: 216.198.139.38
Posted on Wednesday, December 02, 2009 - 10:00 am:
John
In my setup the engine has to be running before the large heater motors will run. They draw so much juice that it will kill the batteries if the generator isn't charging at the same time as they are running. The gen relay has to pull in to alow the motors to run. You could use a jumper wire from the batteries to the terminal on each motor to see if they run okay. Use a large size wire like battery jumper cables and there will be a large flash when you touch the terminal on the motor. Make the connection fast and hold it steady. Do not make the connection at the battery flash as the battery could explode with the normal amount of gas that it generates just sitting.
Bill
Username: Lsilva
Post Number: 328
Posted From: 72.187.35.208
Posted on Wednesday, December 02, 2009 - 10:03 am:
You will have to check your schematics but, yes, I believe that there is a relay operated from the "R" terminal of your alternator that controls power to the motor relay. These fan motors draw a large current and would quickly kill the batteries without the engine running.
If you can find it, you can defeat the circuit and run the fans for testing.
Post Number: 700
Posted From: 71.53.153.91
Posted on Wednesday, December 02, 2009 - 12:37 pm:
On somr of the gmc they use an air pressure switch so that when the pressure builds,the grn will start to charge and a little mor pressure the fans will operate. Some have seperate controls for each.
Gomer
Username: Bigrigger
Post Number: 308
Posted on Wednesday, December 02, 2009 - 1:19 pm:
Well thanks for all the info. I found that there are two solenoinds between the two motors. One goes direct from power to the motors, one goes through a series of what I assume are coils for slowing down the motor speeds. I have power to the "high speed" soloniod but it doesnt operate. I can jump across it and the motors will run. But when i try to jump from the hot side of that switch to the motor side of the "slow speed" switch, the motors do not operate and I get a spark, like something is grounded. Sorry for not describing it better, but as an electrician, I make a great truck driver! My thoughts are that the coils that make them run at lower speeds are somehow not functioning and that has caused the breaker that feeds that "slow speed" solonoid to stay open. Does this make any sense to anyone?
This is like trying to teach advanced calculus to a orangutan!
