Paso One (Paso_1)
Registered Member Username: Paso_1
Post Number: 151 Registered: 11-2004 Posted From: 142.165.246.239
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 08, 2009 - 8:46 am: | |
I'm looking for Tall valve covers for my 6V71 so that I can install the Jake brake solonoids. I was told that the 6V92 valve covers are the same covers and they would be more plentiful and easier to find. I would like the one piece tall covers if I can find them. ( I even have some 8V covers to trade if someone is interested ) But I would like to confirm my information is correct. Thanks in advance |
Dale Waller (Happycampersrus)
Registered Member Username: Happycampersrus
Post Number: 347 Registered: 7-2005 Posted From: 166.225.17.45
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 08, 2009 - 9:28 am: | |
Paul, The 6V71 and the 6V92 valve covers are interchangable. The will fit each other with no problem, But finding the taller ones for the jakes are kinda difficult. There are/was spacers that were made also that were about 1" thick and you just reused your covers. Just had to use 2 gaskets on each one. I couldn't find any covers or spacers, so I had to cut up 2 sets of steel covers and weld up my own covers. Dale |
Tom Christman (Tchristman)
Post Number: 154 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 08, 2009 - 10:46 am: | |
As Dale said, the 71 and 92 3-cylinder valve covers interchange. Highly recommend you find the aluminum ones, rather then the steel. Steel have a tendency to warp and leak. And, hold out for the tall valve covers-the conversion spacer to use your existing valve covers just creates another leak point. Good Luck, TomC |
Rob Norgren (Robsedona)
Post Number: 192 Registered: 11-2007 Posted From: 75.208.200.87
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 08, 2009 - 10:50 am: | |
Yes My 8V71 with Jakes has the taller 8V92 valve covers you should be able to find them used Good Luck |
Paso One (Paso_1)
Post Number: 152 Registered: 11-2004 Posted From: 142.165.246.239
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, December 11, 2009 - 1:00 pm: | |
Thanks Joe and Ralph for the offline leads. I found a set of tall aluminum of a 6V92. Interesting that they have large breathers on the top of them, with fuel mizer decals, first thought DD as a fuel mizer
Post Number: 375 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, December 11, 2009 - 6:15 pm: | |
Hi Paul Where did you find them? Joe. |
Paso One (Paso_1)
Post Number: 153 Registered: 11-2004 Posted From: 142.165.246.239
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, December 11, 2009 - 6:24 pm: | |
Badger Truck parts complete with bolts. and a inch of fresh grease. and overnight shipping. $ 262.50 Canadian bucks Thanks for the tip Joe Anyone else looking Leid Diesel in PA has a set as well. Mark These covers were just removed from an engine . It might be safe to assume the Jakes are still there I never asked. |
