4106 How much weight can bay hold? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2003 » January 2003 » 4106 How much weight can bay hold? « Previous Next »
Charlene (208.18.102.93)
Posted on Friday, January 17, 2003 - 10:49 am:
How much weight can you put in the second bay back on the left side (where A/C unit was)?
Will it hold 900 lbs?
4106
Charlene
RJ Long (24.127.74.29)
Posted on Friday, January 17, 2003 - 2:13 pm:
Yes.
Just balance the load so you don't exceed 12K on the front axle and 20K on the rear. (That's 6K per front tire, and 5K per rear, fyi.)
Have you run your '06 across a set of scales? Might be a good idea. . .
RJ
PD4106-2784
Fresno CA
FAST FRED (209.26.115.217)
Posted on Friday, January 17, 2003 - 3:30 pm:
Have heard from industry PROS that they would often toss an 8V71 into a GM bay.
Don't know what you have in mind but a ton doesn't seem to be a big deal.
Sam Sperbeck (206.230.105.250)
Posted on Friday, January 17, 2003 - 5:18 pm:
Charlene,
I just installed a used 7.5 KW Onan Quiet Diesel (420 lbs) generator in the compartment you are refering to by adding a bolted in framework to mount it on. It was a tight fit so you must be planning to put something quite heavy for its size in there, but I feel that if you build a strong enough frame you won't have a problem. By the way, I am really impressed with how quiet my generator is and with the features it has.
Thanks, Sam
Charlene (208.18.102.3)
Posted on Friday, January 17, 2003 - 8:38 pm:
Thanks for all the info - RJ, Fred & Sam.
Charlene
