Soundbox Materials Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2003 » January 2003 » Soundbox Materials « Previous Next »
Mike M (152.163.188.227)
Posted on Saturday, January 25, 2003 - 10:11 am:
Whats the best sound deadening material to use in the generator box? Where to get..how much clearance needed etc....Thanks! :)
Mike McCarthy
1969 GMC 4903
Forestville CT
Pete (64.12.96.235)
Posted on Saturday, January 25, 2003 - 10:24 am:
Mike,
I used fiberglass duct. you can cut it and square it as needed..it worked pretty good. clearence is about 3 or 4 inched cause the one side is aluminum and can take heat. I am also closing mine totally in and using a 12v fan from a small forign car ( which are waterproof ) to vent the enclosed compartment. If you want one..get it at a local u pull it..10 bucks is a deal
Pete
jc (152.163.188.227)
Posted on Saturday, January 25, 2003 - 11:23 am:
Check out Dick Wright (at Wrico?) in Oregon (web search) he carrries a foam panel with a flexible lead plate imbedded in the foam. It's expensive but you asked what was the best.
christopher (68.160.191.123)
Posted on Saturday, January 25, 2003 - 12:29 pm:
SOUNDDOWN insulation out of salem or marlblehead mass. seel what your looking for i think they have a website.
christopher
Geoff (Geoff) (64.1.0.26)
Posted on Saturday, January 25, 2003 - 12:31 pm:
I got soundbarrier material from West Marine.
--Geoff
'82 RTS CA
Scott Whitney (66.82.9.35)
Posted on Saturday, January 25, 2003 - 10:50 pm:
I used Soundown (only one 'D') for my genset box. It is a quilted fiberglass product with a lead sheet in the middle and an oil and fuel resistant layer on the outside.
http://www.soundown.com/
Scott
Henry R. Bergman, Jr. (Henryofcj) (65.194.145.50)
Posted on Thursday, January 30, 2003 - 10:15 pm:
Does the lead interior of the Sounddown stuff require any special handling or application considerations because of the lead interior?
Reason I ask is that I need to quiet down the floor hatches on my Crown ex-schoolie, applying the product to the underside of the hatches.
Do not know if the lead would/might/could cause health problems later after many heat/duty cycles. Thanks in advance. Henry
Scott Whitney (66.82.9.17)
Posted on Thursday, January 30, 2003 - 10:27 pm:
The lead sheet is not exposed except where you cut the material. And even then, only a thin edge is exposed. Then you use a special tape to seal the cut edge. So the pieces get installed like little custom panels.
I am no chemist/metallurgist but I don't see how it would be harmful.
Scott
Chuck Harris - PD4104 (207.172.11.147)
Posted on Friday, January 31, 2003 - 9:59 am:
Everything I know about lead usage, and health is as follows:
1) lead does not penetrate the skin barrier; handling lead with bare hands will NOT increase your blood lead levels.
2) handling food with unwashed hands that have been handling lead WILL increase your blood lead levels.
3) smoking cigarettes with unwashed hands that have been handling lead WILL increase your blood lead levels. (If you smoke, I see no reason why you should worry yourself about lead poisoning. Your denial system should easily allow you to ignore this life threatening hazard too.)
4) the vapor pressure of room temperature lead is unmeasureable.
If you want a superior lead free sound deadening material, try:
http://www.wilrep.com/panel1.html
They make a sound deadening material using barium sulfate (the stuff of barium enema's and "milkshakes"). It's heavy, cheap, and does a much better job than lead sheeting. And best of all, it's nontoxic.
-Chuck
Geoff (Geoff) (64.1.0.216)
Posted on Friday, January 31, 2003 - 12:02 pm:
The stuff I got from West Marine is similar to Soundown in design only they use a lead substitute:
http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&productId=17973
--Geoff
'82 RTS CA
Henry R. Bergman, Jr. (Henryofcj) (65.194.145.54)
Posted on Friday, January 31, 2003 - 7:06 pm:
Thank you everyone for the great answers/help with the included websites. Love this board! Henry of CJ
R.C.Bishop (128.123.221.148)
Posted on Friday, January 31, 2003 - 10:47 pm:
FYI....I checked the price of lead sheeting today and compared it with cork...both 1/8th inch thick. It will take roughly 5 times the price of cork to do it with lead sheeting.
Cork about $300.....lead approximately $1600. No brainer for me, but thanx FF for the thought provoking information. That is exactly what makes this board crem d'crem. (sp? :) )
Posted on Friday, January 31, 2003 - 10:50 pm:
Think I crossed threads.. Sorry 'bout that :(...look for the other thread :)
