1954 GMC PD-4104 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2010 » January 2010 » 1954 GMC PD-4104 « Previous Next »
Bestekustoms (Mrbreeze)
Username: Mrbreeze
Post Number: 9
Posted From: 174.16.109.152
Posted on Monday, January 11, 2010 - 10:35 pm:
Well The Bus Addiction Countinues At An Alarming Rate. I Need Say No More.....LOL
I Just Bought Myself A 1954 PD-4104 6-71 4 Speed. This Now Makes 7.(Buses) With More To Come. HeHe..
I Have A Question And Am Hoping Someone Can Answer It For Me.... As Always I Would Like To Dig Up Some History On My New Old GMC Girl.
The Vin# Is.. 1400
I Can Read CALIFORNIA SITESEEING TOURS Standing At The Right Angle Across The Front Of The Coach.
I Drove The Coach Home Today.(100 miles) The Thottle Likes To Stick On The Floor. WOW What A Ride That Was In Rush Hour Traffic. I Fixed The Problem By Running A Bungie Cord Around My Boot And The Pedal. Worked Great Until I Had To Hit The Brakes..LOL. But, I Got-Er-Done.
I Am Leaving Tomorrow To Head Out West (Long Beach Ca)To Pick Up My 1976 Crown(Monster Coach) And Then To Lake Havasu Az To Grab My 60 Series Crown And Then Onto The RALLY At QUARTZITE.....
I Hope To Meet Many New Friends All With This Same Crazy Sickness Known As The BUS NUT SYNDROME
10-4...10-4
Any Help On History Of The 4104 Will Be Greatly Welcome.
Thanks JOHN
David Guglielmetti (Daveg)
Username: Daveg
Post Number: 135
Posted From: 69.106.222.252
Posted on Monday, January 11, 2010 - 10:40 pm:
I'm not sure if "nut" can accurately describe your condition!
Good luck and have fun with all that iron.
Username: Dreamscape
Post Number: 622
Posted From: 64.40.215.165
Posted on Monday, January 11, 2010 - 11:44 pm:
John,
You will get good help and advice about getting to know your new toy!
Good Talking with you tonight buddy!
Wish I could help, but you're beyond that! ;)
Paul
Username: Gusc
Post Number: 1063
Posted From: 208.54.196.227
Posted on Monday, January 11, 2010 - 11:47 pm:
My 4104 is s/n 1274, just a bit older than yours.
RJ will know the history. I tried my old link to GMC bus deliveries but it has closed down??
RJ,
Please post the new link if you have one.
Donnie Daugherty (Dr_detroit)
Username: Dr_detroit
Post Number: 10
Posted From: 74.87.222.126
Posted on Tuesday, January 12, 2010 - 1:17 am:
PD4104-1400 Delivered new to New Mexico Transportation Co in 1955 along with #1399. My list does not have the Month delivered but I am sure that RJ will have it on his list.
Hope this helps,
Donnie Daugherty
Enterprise Alabama
PD4106-2772
PD4104-3495
Username: Mrbreeze
Post Number: 10
Posted on Tuesday, January 12, 2010 - 1:19 am:
Heres A Couple Of Pictures Of The Old Girl...
[IMG]http://i956.photobucket.com/albums/ae49/Bestekustoms/DSC00124.jpg[/IMG]
[IMG]http://i956.photobucket.com/albums/ae49/Bestekustoms/DSC00129.jpg[/IMG]
Hope That Works...First Time Posting Pictures Here.
Enjoy..
JOHN
Username: Rjlong
Post Number: 1671
Posted From: 67.182.48.162
Posted on Tuesday, January 12, 2010 - 4:29 am:
John -
PD4104-1400 was delivered new in May of 1955 as fleet number 186 to New Mexico Transportation Company, based out of Rosewell, NM.
JLV (Roadrunner Tex) will clarify my belief that NMT is/was a Greyhound affiliate.
FWIW & HTH. . .
Post Number: 1059
Posted From: 66.82.9.58
Posted on Tuesday, January 12, 2010 - 6:04 am:
As a guess the accelerator cable on an 04 is similar to the 06.
On the 06 the cable runs thru 1/4 inch brass pipe and is easily replaceable.
Get Da Book , pull the cable and soak it in diesel lube the cable with Da Book's recomendation , although I chose teflon grease instead.
IF this doesn't cure it you will have to look, its probably a break in the cable housing , again call Luke at US Coach for the parts .
FF
Username: Vivianellie
Post Number: 422
Posted From: 74.4.48.228
Posted on Tuesday, January 12, 2010 - 6:33 am:
Good Lord -
A true glutton for punishment.:-)
Nellie Wilson
Username: Bigrigger
Post Number: 330
Posted From: 24.183.21.246
Posted on Tuesday, January 12, 2010 - 9:20 am:
Sounds like it's time for a twelve step program. Please read this carefully, that is steps not busses!
Austin Scott Davis (Zimtok)
Username: Zimtok
Post Number: 394
Posted From: 209.156.24.114
Posted on Tuesday, January 12, 2010 - 10:09 am:
My 4104 had a sticking throttle cable.
I pulled back the rubber boot (what was left of it) back by the engine and sprayed PB Blaster down the casing.
Let it soak in and worked the throttle cable in/out, then sprayed more.
I used my air compressor to blow/force the PB Blaster further in. I repeated this spray-force-work the throttle until the cable was moving freely.
That solved the sticking problem, then about 3 months later the cable broke at the back of the bus just where it turns up from under the bus to go to the engine. the cable had rusted inside the casing which caused the binding first then it finally broke after I cleaned it.
I removed the cable from the compartment under the drivers seat and just pulled it out. I then removed the other end of the cable from the engine bay. The cable was very rusty where it had broke.
To clean the casing I sprayed lots of PB Blaster in through the engine end of the casing. Then I used a part of the cable I pulled out chucked into a drill as a snake to clean the casing. Over and over I would spray PB Blaster and drill/snake until I thought it was clean. Then I flushed the casing out with compressed air and mineral spirits.
I replaced the cable with new 3/16 cable from Home Depot. First using a grease gun to pump grease into the casing and then greasing the cable the full length as I pushed it into the casing.
I reattached the ends and replaced the HEAVY spring someone had put on with a lighter spring.
The throttle has been working great for 2 years so far and the lighter spring makes driving a lot more enjoyable...
Post Number: 752
Posted From: 71.53.153.91
Posted on Tuesday, January 12, 2010 - 10:14 am:
MrBreeze; I have a 57 4104 and I found the excellerator pedal was sticking at the pedal. I took the grease fittong out and soaked it with PB Blaster, let it sit a while and put in a new grease fitting,No more problem. That area gets a lot of dirt from your shoes and such. That is the first thing I would check and then go for the cable.
Gomer
J.L.Vickers (Roadrunnertex)
Username: Roadrunnertex
Post Number: 72
Posted From: 74.5.101.242
Posted on Tuesday, January 12, 2010 - 6:53 pm:
New Mexico Transportation Company home office was located in Roswell,NM.
The old ex New Mexico Transportation Company bus station on North Main is still in operation to this date.
Note:That New Mexico Transportation Company was in part owned by the Greyhound Corp.
New Mexico Transportation Company is no longer it was bought by TNM&O Coaches in Lubbock,Texas many years ago.
Now TNM&O is no longer as it was bought by the now Greyhound Lines.
New Mexico Transportation Company had some very good equipment in later years it was GMC and MCI equipment.
Many years ago when I was stationed in Roswell,NM at Walker AFB (SAC) and got to ride on a New Mexico Transportation Company PD-4106 from Amarillo,Texas to Roswell,NM and that old 4106 was a very fast bus back then we made the trip in record time.
New Mexico Transportation Company is long gone but the memories still linger on.
Take care of the old PD-4104 paint her the old Greyhound Blue and white and it will look like a New Mexico Transportation coach again.
jlv
Username: Gusc
Post Number: 1065
Posted From: 208.54.196.240
Posted on Tuesday, January 12, 2010 - 7:44 pm:
OK John and RJ, share the source of this information with the rest of us!!
Douglas Wotring (Tekebird)
Username: Tekebird
Post Number: 407
Posted From: 71.59.75.212
Posted on Tuesday, January 12, 2010 - 7:55 pm:
JOhn,
I probably still have some 04 body parts and other bits around...some brand new if you need some stuff
Username: Mrbreeze
Post Number: 12
Posted on Tuesday, January 12, 2010 - 8:49 pm:
Thanks Guys & Gals,Its Great To Here All That Great History. Wow A Greyhound Bus.... Well I Got A Couple Trailways Already So Why Not A Hound To Go Along With The Herd.
This Bus Came With Both Of The Books.(Maint. & Parts)
As Far As The Throttle Cable ..... Thanks For The Info.My Superior Coach's Throttle Did The Same Thing.I Used Air To Get Lube Up In There.. I Will Soak This One Soon. As Of Now I Just Havent Had Time. I Just Got Her Home Last Night As The Sun Was Going Down. This Bus Has Sat In A Field For Some Years. ( Fired Right Up.. And Purrs )
I Looked Her Over Very Good Before I Handed Over The GREEN BACKS. I Bet I Spent 4-5 Hours Looking At Everything. The Bus Is VERY Solid !! The Only Rust I Could Find Was A Small Spot At The Front Of Each Corner.Next To And By The Lower Fog Lights.& THATS IT !! Well I Guess There Is A Little On The Engine Cover Braces. But Over All This Is A Very Solid Old Girl.
And As Far As Parts Go... Well.. YES. What Do You Have In Body Parts And Other Stuff Doug??. Also The Bus Is Gutted (Yea Sad) I Would Like To Find The Chrome Rail That Runs Around The Driver Seat. Im Not Sure Yet What All Is Missing Inside. But Not Much. The Seats Are Long Gone. Thats For Sure.
Nellie You Have A 4104 Right?
Thanks Guys....
JOHN
ED Hackenbruch (Shadowman)
Username: Shadowman
Post Number: 223
Posted From: 75.211.86.195
Posted on Tuesday, January 12, 2010 - 9:14 pm:
Nellie has a 5C
Username: Tekebird
Post Number: 409
Posted on Wednesday, January 13, 2010 - 12:42 am:
shoot me an email directly
tekebird@yahoo.com
Username: Mrbreeze
Post Number: 13
Posted on Wednesday, January 13, 2010 - 1:04 am:
I Just Went Outside And Looked The Bus Over Somemore. I Can Plainly See The Numbers 186 Below The Window On The Entrance Door.. !!!
VERY COOL. YES, I Will Have To Paint Her Back To The Original Colors As A Greyhound.
All I Need Now Is Some Original Seats And Stuff For The Inside Like That.
Someone Had Converted The Bus Many Years Ago.I Was Told That The Bus Was In Alaska For Many Years. The PO Gutted The Bus In Order To Re-Do It. Im Glad He Lost Interest. Heck,I Already Have A Converted Bus. I Dont Need Another. But, Seated Coaches Are COOL, Original And Apart Of Our History.
Thanks Everyone.
You Cant Tell Im Excited Can You..???
JOHN
Post Number: 73
Posted on Wednesday, January 13, 2010 - 8:59 pm:
Our source of information for GMC intercity Coaches.
RJ Long and my self have the same list for the GMC intercity coaches.
The list dates back to the old PD-3751 Silversides and goes through to the last GMC Intercity Coach that was built H8H649.
The list has each GMC coach type and serial number and the date it was built and the 1st bus company that bought it when it was new from GMC.
I do not have any information on the MCI coaches sorry.
Some Eagle owners have a serial number list for the Eagle model production.
jlv
Username: Dmd
Post Number: 412
Posted From: 173.68.141.245
Posted on Wednesday, January 13, 2010 - 9:25 pm:
JL and RJ, could you find any info on our PD 3751 #1133. It ended up near Ashville NC before we bought it. Thanks.
Username: Rjlong
Post Number: 1672
Posted on Wednesday, January 13, 2010 - 9:26 pm:
Gus -
Well, I simply reach over and pull a binder off the shelf of the bookcase next to my computer desk to look up the info. :-)
FWIW & HTH. . .
Username: Gusc
Post Number: 1066
Posted From: 208.54.196.244
Posted on Wednesday, January 13, 2010 - 9:56 pm:
RJ,
Thanks. That list used to be on a website called something World but the site is closed down. I thought you had a new website.
I should have copied that list when I had a chance!!
However, since I probably will keep my 4104 the rest of my life I probably won't need it anymore. I got all I could find about mine.
Username: George_mc6
Post Number: 954
Posted From: 99.172.183.72
Posted on Wednesday, January 13, 2010 - 10:00 pm:
JLV,
The number is 7853, the 20,000 number is long gone.
G
Post Number: 427
Posted on Thursday, January 14, 2010 - 4:00 am:
Ed -
Yup. A 5C is correct. Gosh you have a good memory... I had to go check the maunufacturer's plate. :-)
Nellie
L James Jones Jr (Jamo)
Username: Jamo
Post Number: 124
Posted From: 24.59.114.207
Posted on Thursday, January 14, 2010 - 7:09 am:
It's way easier to just check your profile, Nellie...
Tim Hoskinson (Tdh37514151)
Username: Tdh37514151
Post Number: 255
Posted From: 65.25.139.50
Posted on Thursday, January 14, 2010 - 8:59 am:
Dave Pd3751 1133 was delivered to Southwestern Greyhound Lines 1948
Username: Bigrigger
Post Number: 332
Posted on Thursday, January 14, 2010 - 3:20 pm:
I was always pretty impressed by her profile...
Username: Dmd
Post Number: 413
Posted on Thursday, January 14, 2010 - 8:14 pm:
Thanks Tim, could you send me your address again with phone #, i am organizationaly challanged. There was only one Silversides in Arcadia this year but it was sweet, especially the engine set up. DDEC inline 6!
